Old 08-13-2018, 04:38 PM   #1
Jacks won't retract
Tried everything including manual override with a drill and socket.
HELP!!!!
2015 FR3
Dylvinia is offline   Reply With Quote
Old 08-13-2018, 04:57 PM   #2
edm
Have you checked the 100 amp circuit breaker on the right side above the batteries? The breaker has a red flag sticking out if it is tripped , if it is tripped just push the flag back down to reset.
Good luck.
edm is offline   Reply With Quote
Old 08-13-2018, 04:59 PM   #3
Lacey's Spring, AL
formerFR's Avatar
you blew/tripped a Main BUS fuse/breaker, probably in the battery bay, on the wall, may have a little red or yellow flag protruding, push it back in.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 08-13-2018, 05:18 PM   #4
Solved!
After being very annoyed and almost giving up I retraced my steps tapped everything with my maglite and double checked all connections and fuses and when I had pushed the red flag fuse in the battery Bay in apparently I hadn't pushed it in far enough because I hit it again and it clicked and boom everything worked perfectly. Thanks so much for your replies guys appreciate it and learning more about my RV every day lol
Our circumnavigation of the nation over the next few months continues!!!
Dylvinia
jacks
