Old 09-28-2014, 04:55 PM   #1
Harleyreb's Avatar
Just bought 2015 FR3 30DS - what are these?
I still cannot figure out what these extensions are for. Any takers?
Name:	ImageUploadedByForest River Forums1411941318.084991.jpg
Thanks.
2015 FR3 30DS
2014 Jeep Cherokee Latitude
2017 Jeep Wrangler
Harleyreb is offline   Reply With Quote
Old 09-28-2014, 05:07 PM   #2
fonzie's Avatar
Most likely it is for operating your slide manually.....look at page 5 and 14 of attachment....
http://norcoind.com/bal/downloads/ac...ice-manual.pdf
Fonzie
Old 09-28-2014, 05:14 PM   #3
Harleyreb's Avatar
That's it, many thanks. They were just in a bag with no documentation along with them at all.
2015 FR3 30DS
2017 Jeep Wrangler
Old 09-28-2014, 05:29 PM   #4
tncruiser's Avatar
it could just be tool left behind by workers,while at Goshen ralleye I found 1 of those on the road mine had a phillips head driver on 1 end
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 09-29-2014, 08:09 PM   #5
b1barnes's Avatar
I received one also in my kit of stuff.
b1barnes is offline   Reply With Quote
Old 09-29-2014, 08:46 PM   #6
camaraderie's Avatar
It is for your electric drill to insert into the slide motor matching nut to pull in your slides if they ever fail to work. If you have the cable type slides...I am told that this motor is behind the upper horizontal framing trim inside the RV on the slide and that once the trim is removed...the flex extension is needed to reach the motor to turn it. Memo... carry a drill!
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 09-29-2014, 09:09 PM   #7
Harleyreb's Avatar
I do have the cable slides, and I always carry a drill. I did see from the documentation posted above how to use the extensions on the motor. I just hope the front trim comes off easily if needed.
Thanks for the replies.
2015 FR3 30DS
2017 Jeep Wrangler
Old 10-01-2014, 09:40 PM   #8
Tool to close or open your slides manually if something happens to your slide motor. Fits on the end of a drill.
johnpisue is offline   Reply With Quote
