Old 08-10-2016, 04:08 PM   #11
The range fans are pathetic. Hold your hand under your fan. Is the air going towards or away from the fan? If it's going away, the fan motor is wired backwards. Take the metal cover off where the wires go in & reverse the two wires supplying power. You may need 2 marettes. The wires are usually black & white. Mine was reversed. Believe me you'll be an expert on trailers in no time.
Ian Walker is offline   Reply With Quote
Old 08-11-2016, 08:51 AM   #12
Wolverine 1945's Avatar
You can also hold something under the hood that produces a little smoke,,, to see how well it fan works,,, just be prepared for the smoke detector to go off !!!
Wolverine 1945 is offline   Reply With Quote
fan, newbie
