Old 09-09-2014, 08:19 PM   #1
Brewster McFrisk's Avatar
Kwikee step switch not working
My 25 step series step works when you open / close the door but switch when flipped makes no difference the strip still works the same. RV came back from dealer when I discovered it. Also the blue light isn't on in the switch which leads me to believe there is a fuse somewhere for the switch which is what the owners manual says but here is the question where is this 6 amp fuse located on the DS25 RV. I've looked all over short of cutting the cable tie holding a big way of wires by the motor underneath. Any one come across this?
Brewster McFrisk is offline   Reply With Quote
Old 09-13-2014, 09:47 AM   #2
Solution Found
In the battery compartment above the batteries you will find a black box marked "battery control box". Carefully open the box cover and inside you will find a 5 amp fuse marked "esp". This is the fuse that controls the step switch.
