Originally Posted by TheWolfPaq82
All due to....GET THEM OUT THE DOOR AS FAST AS YOU CAN. Slap on some glue toss on the membrane, move to the next station. Just poor arse quality.
If not warranted easy fix. Splice it, check substrate to make sure it is sound. Adhere using solvent based adhesive. Install like contact adhesive...butter both deck and under membrane. After that use a t-joint cover or Eternabond self adhered. Bubbles are due to off adhesive is off-gassing. They had a puddle there instead of even distribution of adhesive. BEFORE doing anything wait. Many times the membrane wiil shrink back down to substrate. Give it some time, unless you know you have a leak. Best.
