Old 10-11-2017, 06:42 PM   #1
Leak!
Hi new RV'er and owner here. Just picked up my '17 30DS last week and haven t taken it anywhere but my driveway as of yet. Went out to put something in the coach The other day and discovered there was a water trail leading from the front corner of the bathroom wall back towards the bedroom. Note I have not hooked up to any water at all with the exception of the walk-through at the dealer when I picked it up. I looked and could not see a water trail coming from the side wall between the slide and the wall. Note I have not hooked up to any water at all with the exception of the walk-through at the dealer when I picked it up. I looked and could not see a water trail coming from the slide wall between the slide and the Bathroom wall. Took it to the dealer so they could take a look and try to figure it out but I am at a loss here. I highly doubt it’s something extensive as the unit had been sitting on their lot and they say they go through them routinely to check them out for leaks and such. I’m hoping that a leaf or something got stuck between the wall and the seal for the slide or something like that. The only thing I’ve done to it so far is put vent covers on roof and I looked around up there when I was up there and didn’t see anything looked out of sorts. Has anyone had any issue Like this and if so what was the cause. Thanks for your help
afrevele is offline   Reply With Quote
Old 10-11-2017, 08:30 PM   #2
I received a recall letter from Forest River on mine pertaining to roof leaks.
GM_LA is offline   Reply With Quote
Old 10-11-2017, 08:45 PM   #3
Did it rain?
2016 Siverback 33IK
dalford is online now   Reply With Quote
Old 10-11-2017, 09:05 PM   #4
Yes it was just after a rain, the slides were in and I always let the motor slow so I know it’s fully retracted. But also it’s been on their lot for a while I’m sure. So it should have leaked before,
Old 10-11-2017, 09:06 PM   #5
What year is yours? And what was the recall for?
Old 10-11-2017, 09:59 PM   #6
GT Traveler's Avatar
Recall is for "potential sealant issue allowing water infiltration into the vehicle roof" as explained in Technical Service Bulletin 68-0488, published September 29, 2017. Contact your dealer without delay.
Effected Models: 2017-2018 FR3 models F3A25DS, F3A25DSF, F3A28DS, F3A29DS, F3A30DS, F3A30DSF, F3A32DS, and F3A32DSF.
2017-2018 Georgetown models are also effected as well.
Mark & Connie
2020 GT5 31R5
2006 GMC Canyon (toad)
GT Traveler is offline   Reply With Quote
Old 10-11-2017, 10:21 PM   #7
Wow thanks!
Old 10-12-2017, 07:47 AM   #8
The dealer told me that the repair takes 12 hours on longer if there is a leak they have to wait for the wood to dry. The cap rail on the top will be replaced with a wider one to correct the problem.
Old 10-13-2017, 04:22 AM   #9
rk06382's Avatar
Service Bulletin 68-0488 Georgetown & FR3 Roof Leak With Sealant Issue
I also received a letter. I have already talked to a local dealer and he said he would have to order a repair kit.
Please check your VIN on Forest River search for recalls.
I check my VIN and it came back with:
"Service Bulletin 68-0488 Georgetown & FR3 Roof Leak With Sealant Issue"
Link to Service Bulletin 68-0488 PDF
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is offline   Reply With Quote
leak
