leak on front slide out
Have had my 2015 fr3 in and out of the shop (6 months in) in the past year with them trying to find an intermittent leak. at times the slide is out during a light rain and then when I retract it and then go make a left turn water runs out at the front and rear of the slide , on the floor, it varies from a Lot to not so much .sometimes nearly a half a gallon. I do check the top of slide and dry it off after retracting it . most of the time it is only damp on the top. It appears to be puddling inside of the slide somewhere and then running out. JUST CANNOT FINE THE ENTRY POINT.
HAS ANYONE HAD A SIMILIAR PROBLEM???? HAVE BEEN WORDKING WITH THE FACTORY REP AND THE MAINT PEOPLE WITH MOTOR HOME SPECIALISTS.
THEY HAVE DONE A LOT OF SEARCHING BUT JUST CANNOT FIND THE SOURCE, ESPECIALLY SINCE IT SEEMS TO BE INTERMITTANT PROBLEM.
