Had the same issue and bought my replacement water valve part off Amazon. Ended up pulling the entire toilet off because there wasn't enough room back there to comfortably work. It took a total of maybe 10 minutes to pull toilet, replace part and reinstall. Hopefully you can do this without having the mess with the pex tubing because if you do it will require a special tool for cutting the current clamp as well as a separate tool to reclamp the fitting.
2016 Vibe 250BHS
2021 Chevy Silverado 2500 HD w/ 6.6L diesel engine
Husky Center Line TS Hitch.
