Old 08-17-2018, 01:57 PM   #1
gomatthew's Avatar
Leather Upholstery Wear & Tear
I'm in a 2015 FR3 DS30 with only 20k Mike's on it. The brown leather Upholstery is rubbing off everywhere. How have you addressed this? Any maintenance tips for oils or covers that you recommend? Click image for larger version
ID:	183523Click image for larger version
ID:	183524Click image for larger version
gomatthew is offline   Reply With Quote
Old 08-17-2018, 02:11 PM   #2
clr
I had the same problem with my 2015 Prime Time Sanibel and was told by them that they would "do something for me" but they would not replace the furniture at the International FROG rally. I found that recovering the furniture would cost as much or more as replacing the furniture. We got a new theater seating arrangement from RecPro and are very happy with it. I have heard that some have been replaced during the warranted period but most seem to happen just outside of that.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 08-17-2018, 02:19 PM   #3
It's not leather. Same stuff that's in my Montana. At best, it's bonded leather, which is a marketing scheme to sell you. Bonded leather can have as little as 6% percent leather shreds that are mixed with materials similar to vinyl. A good quality vinyl will last way longer than bonded leather IMHO. Choice is to cover it or replace, at great expense.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 08-17-2018, 03:08 PM   #4
leisurelarry's Avatar
Originally Posted by gomatthew View Post
I'm in a 2015 FR3 DS30 with only 20k Mike's on it. The brown leather Upholstery is rubbing off everywhere. How have you addressed this? Any maintenance tips for oils or covers that you recommend? Attachment 183523Attachment 183524Attachment 183525
I also have a 2015 30DS with 20,000 miles on it. My interior seating surfaces are the lighter shade of brown, no dark brown trim. Luckily I have not experienced any deterioration to the surfaces. Is it just the dark brown surface areas that are deteriorating?
leisurelarry is offline   Reply With Quote
Old 08-18-2018, 01:52 PM   #5
Send a message via MSN to Tiggerdad
^^^^^^This
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 08-18-2018, 02:15 PM   #6
I have a 2015 30ds. And have stayed in it for over 400 days. And no wear and tear... that’s pretty sad
colourful64 is offline   Reply With Quote
Old 08-19-2018, 02:31 AM   #7
I have a 2015 FR# 30DS that is garaged and has just over 10K miles on it. The mileage was racked up on two cross country trips, the only time it was not in the garage. About a year ago I noticed the "leather" was flaking off and leaving the cloth material visible. Did not think much about it because I thought I must have scraped my drivers seat somehow. The same thing happened to the passenger's seat. I pulled the tag off the bottom of the seat and called the maker of the seat. I was told by the owner of the company that he told Forest River that the material that FR selected was made in China and was the worst material he ever had and used. He recommended to the FR manager in the purchasing department that it should not be used. The manager asked him "if it will last for the warranty period" and he was told "that it would last for a year then FR is out of the loop". FR knew it was junk material but did not care "just so long as it would last for the warranty to run out". I just spent almost $1,200 for 2 new seats. Great attitude toward their customers. We have had many motorhomes that cost much more that a FR DS30 and never had such junk. I have spent over $15,000 on the coach to make it reliable. Hopefully, I have succeeded since no problems have arisen during our last short trip (600 miles) to the Keys. I forgot to mention that the paint on the front cap is deteriorating badly and I just sealed the front cap/roof seam and antenna mount because of a water leak running down the inside of the windshield
fedatty is offline   Reply With Quote
Old 08-19-2018, 10:09 AM   #8
Wolverine 1945's Avatar
Not sure it will help but we condition out seats at least once a year !!!
And do every thing we can do to keep the sun out !!!
That drivers seat reminds me of my last office chair !!!
Bonded Leather !!! A Super Bad product !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-19-2018, 12:50 PM   #9
We found that out on an expensive dinette set. When we tried to clean the leather, the die washed off.
PenJoe is offline   Reply With Quote
Old 08-20-2018, 03:08 PM   #10
45RPM's Avatar
We had the same problem in our 5th wheel and have done a lot of research. I found this to be the best solution short of replacing the seats:
-Rich
45RPM is offline   Reply With Quote
