Old 10-01-2018, 02:03 PM   #1
Tents2RV
LEV2 box
I have a 2015 FR3 30DS with an unidentifed
box labeled LEV2 on the underside of the coach. There is a ribbed black tube coming out of it that looks like it has been chewed. The tube is about 12 inches long. It has an end cap on it and there are no wires inside. Is it important and what does it do? I will attempt to attach a picture. Thanks for any info and advice.
c0nnd0r is offline   Reply With Quote
Old 10-01-2018, 03:57 PM   #2
leisurelarry's Avatar
I have a "15" 30 DS model also and don't believe I have ever seen that on the underside. Would love to know what it is just in case.
leisurelarry is offline   Reply With Quote
Old 10-01-2018, 04:24 PM   #3
Tents2RV
The box is about half way back on the driverís side. The picture I attached didnít post. Will try again. (Am using an iPhone and will switch to a desktop if this doesnít post a second time).
Old 10-01-2018, 05:10 PM   #4
Tents2RV
3rd time might be the charm???
This is the black box
Name:	FR3 Black Box.PNG
Old 10-01-2018, 05:34 PM   #5
So that is directly behind the generator. Looks important, I'll have to take another look !
Old 10-01-2018, 06:35 PM   #6
Tents2RV
Let me know what you think. Thanks
Old 10-01-2018, 08:23 PM   #7
FR3Traveler's Avatar
I would say this looks like the emission control evaporation canister between the engine and fuel tank. That is what is behind my generator on the left frame rail.
Mark & Connie
FR3Traveler
2017 FR3 30 DS
2006 GMC Canyon (toad)
FR3Traveler is offline   Reply With Quote
Old 10-02-2018, 07:34 AM   #8
Tents2RV
How critical is that ribbed tube that is chewed?
Thanks for your response.
Old 10-02-2018, 10:52 AM   #9
Just relooked at mine and it has no ribbed cover. There are 2 tubes that connect to the emission system, 1 additional short tube is a vent and 1 electrical sensor connector. This would be a Ford item versus Forest River item if my guess is correct. This may help in your search.
The ribbed section on yours might just be a cover over an internal tube. As long as the tube is complete then no issue. If not, and it is what I believe, then you will eventually get a "Check Engine" light on the dash for emission control system problem.
Mark & Connie
FR3Traveler
2017 FR3 30 DS
Old 10-02-2018, 11:55 AM   #10
HortMi's Avatar
LEV2 is part of the Ford Emission system. I'd check and make sure none of the wires are bare and then wrap it up with electrical tape to keep water out.
HortMi is offline   Reply With Quote
