Old 04-14-2015, 10:18 AM   #1
Leveling jacks won't retract.
Checked hydraulic. Shows half full.
Batteries show full charge.
Any suggestions?
jbutch is offline   Reply With Quote
Old 04-14-2015, 10:40 AM   #2
R&J Silverback's Avatar
you have a micro switch on the control module. follow hydraulic lines to the control unit( black box ) size is 1 1/2 " X 4"long and you will find 3 little buttons on the side push in and you will feel the one that resets. hope this help's
Ron & Jan and black dog(Bella)
2011 Ram 3500 crew cab 4x4, 6sp manual,342's 8ft.bed
2014 CC Silverback 29ik
R&J Silverback is offline   Reply With Quote
Old 04-14-2015, 07:00 PM   #3
Thanks. The breaker in the battery compartment tripped. When I reset it everything worked.
Nothing in the manual suggested this.
Thanks for your response.
Old 04-21-2015, 11:30 PM   #4
PDG
PDG's Avatar
This happened to me. Called Lippert and they said jacks will go down with resouvoir half full but not up. Filled tank and jacks retracted. Hope this helps.
Peter & Linda
2014 FR3 30DS - Fiat 500
PDG is offline   Reply With Quote
Old 04-22-2015, 12:34 PM   #5
b1barnes's Avatar
Mine did this at dealer walk through. Went down until all four wheels were off the ground and then tripped the 100 amp breaker. They couldn't get them to retract and found a wire harness with a diode was faulty. Got to see how to retract the jacks. The harness was replaced and have not had trouble since.
b1barnes is offline   Reply With Quote
Old 04-23-2015, 08:53 AM   #6
My jacks extended fully in my driveway @ Xmas. They lifted the rig completely off the ground on a sloped driveway. Needless to say I was a little worried. The roadside assistance number wasn't much help and gave me the wrong info on how to manually retract them (you have to fully disconnect all power to the solenoids prior to manually retracting them). After a couple of hours of fiddling with it, I pulled up a youtube video and wha-la, was able to get them up.
Sent it back to the dealer and it was a faulty diode. They work fine now but I will always carry a drill and the correct bits so that I can manually retract them on the road, if I need to.
Meathouse is offline   Reply With Quote
Old 04-23-2015, 12:04 PM   #7
wayne and sherry's Avatar
What bits do ya need to used for manual operations?
JeNNY (2015 FR3 / 30DS)
2000 Jeep TJ Moab Rock Crawler
2013 Jeep JK
wayne and sherry is offline   Reply With Quote
Old 04-24-2015, 09:19 AM   #8
What weight hydraulic fluids are used in the leveling system?
2013 Jeep JK
Old 04-24-2015, 09:19 AM   #9
Name:	ImageUploadedByForest River Forums1429885182.982879.jpg
2013 Jeep JK
Old 04-24-2015, 02:00 PM   #10
PDG
PDG's Avatar
Lippert told me to use DX3 automatic transmission fluid, which I did. Works fine, no problems.
Peter & Linda
jacks, leveling
