Old 09-03-2018, 01:17 PM   #1
Tents2RV
Leveling pads hydraulic pump fuse location
I have a 2015 FR3 30DS. Started it up and all looked normal. Released the parking brake and the LCI leveling pad light for pad still down came on. At the same time I heard a surging sound. Set the parking brake and the sound stopped. Stepped outside and found a puddle of red fluid on the ground under passenger side of the coach. Iím guessing a hydraulic line sprung a leak. Where is fuse to the pump? I need to disable pump so I can drive unit to repair shop. (Or is there another way to disable pump?)
Thanks for your help.
c0nnd0r is offline   Reply With Quote
Old 09-03-2018, 01:40 PM   #2
rk06382's Avatar
Library: Forest River Forums - Downloads - FR3 Battery Control Center Schematic 5-31-16 11796
100a Circuit breaker in battery compartment.
Name:	FR3 Leveler Curcuit Breaker.jpg
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is offline   Reply With Quote
cat, fuse, hydraulic, leveling, location, pump
