11-12-2018, 01:42 PM
Leveling system question
Greetings. New to the forum so hopefully I am posting this in the right section.
This is the first time we've owned and RV with an auto leveling system which is friggin awesome.
My question is should I get some treated 2x6 wood pieces to have with us to place under the leveling feet just in case we ever end up on surface that is not 100% solid?
Anything else we should keep in mind or take with is to insure that leveling system remains 100% effective when we're traveling?
TIA!
11-12-2018, 02:19 PM
I have never used anything under my pads in the 5 years I've had my DS30 and I've leveled on all types of surfaces. Although I see many people using wood and/or lego type leveling blocks. I never use auto, too much back and forth with that mode. Strictly use manual and a small leveling float on the floor right behind the engine cover. Also see if the bathroom door stays put when opened part of the way. I level the front, then the rear, then the left or right sides marking sure all for jacks are touching the ground. Best wishes, and happy trails!
11-12-2018, 02:45 PM
Great feedback! Thank you. Didn’t dawn on me to use manual and control how the leveling happens
11-12-2018, 02:57 PM
TIA!
Some RV parks with "Blacktop Sites" Demand that Pads be placed Before using Hydraulic Levelers! If you look at blacktop sites you will see the "Depressions from NOT using large Pads"! Youroo!!
11-12-2018, 02:59 PM
What make and model is your RV?
There are a lot of tips and tricks for the various leveling systems and you'll definitely want to hear from the people who have your unit . . .
One quick tip on the auto level is to make sure no one is moving around inside the unit while leveling as this will result in false readings as the auto leveler does it's thing (thereby increasing the time and cycles to get your unit level).
Enjoy!
2015 Berkshire 34QS
11-12-2018, 03:54 PM
One quick tip on the auto level is to make sure no one is moving around inside the until while leveling as this will result in false readings as the auto leveler does it's thing (thereby increasing the time and cycles to get your unit level).
Enjoy!
FR3 30DS. Thanks for your input!
11-12-2018, 10:48 PM
I installed SnapPads on my FR3 28DS. They are made from recycled rubber. They will not slip in concrete or asphalt. I also have two 4x10x24 treated wood blocks left over from my Class C, but I rarely use them.
SnapPads in action:
Boondocking at Cabela's Store in Anchorage, Alaska.
Level with only the left front wheel was off the ground.
Boondocking Richardson Highway 65 miles north of Valdez, Alaska.
Level with both front wheels are off the ground.
If the ground is not level, park with the front a little lower than the rear. Never lift the rear wheels.
I love my SnapPads.
11-12-2018, 11:15 PM
Wow we have a 28DS also. With Snap pads! They are great on Gravel too. They protect the foot of the leveler.
11-15-2018, 07:56 PM
Never knew about these Snap Pads. Genius! I use Hush Pads and I keep some 4x6 blocks with me as well. I do not like to have my jacks fully extended. I also carry Camco RV Tri-Levelers as I also do not like to take my front wheels off the ground. We do quite a bit of desert camping and mother nature does not tend to make the earth anywhere near flat and level.
https://www.campingworld.com/hush-pa...h-leveling-pad
https://www.walmart.com/ip/Camco-RV-...ellow/29764486
Happy trails!
Antone
2015 FR3 30DS
2011 Jeep Wrangler 2D toad
11-16-2018, 12:31 AM
SnapPads in action:
Attachment 191298
Attachment 191299
Attachment 191301
Attachment 191300
I love my SnapPads.
What size did you put on ...I have a 30 ds and think they use the same foot ...are they both the same size front and back...
11-16-2018, 05:10 AM
9 inch. SNAPPAD XTRA website
SnapPad XTRA is our best seller. Designed specifically for 9-inch round jack feet common to LCI's Level Up and Ground Control systems, XTRA is compatible with a wide variety of Fifth Wheel trailers, as well as some Class-A Motorhomes. Snap on a set of XTRA's to your rig and eliminate all of you leveling hassles. Permanently. Amazon: RV SnapPad Permanently Attached Leveling Jack Pad for 9 inch Round Metal Feet
Once on, they same on. No getting out to put down blocks.
Measure the bottom of your jackpads for the SnapPads, they should be 9 inches, the same as mine.
11-16-2018, 06:09 AM
Our leveling system is very sensitive to non level sites.
I bought a 2x10 and cut it in squares.
Screwed two together to make 4 3” thick blocks. And a few 1.5” ones.
Also carry a set of legos. I try to get all the cylinders extending about the same length.
I usually use most of them plus two pieces of 6x6 in front.
Ours is a fiver. For some reason the leveling system goes batty on anything but fairly level sites. Have to use manual mode.
12-03-2018, 07:05 AM
TIA!
we have a 30ds and it would lift the from wheels off the ground at the littlest sloped pitch. i don't believe the factory set the level point. you can reset the level point yourself and problem should be done every once in a wile for good measure. i found the instruction on You-tube. https://youtu.be/XfmYX0kfwj0
2018 FR3 30DS
1997 and 2018 Wrangler
12-03-2018, 10:38 AM
I concur with everyone else on SnapPads. Simple, easy, effective
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
12-03-2018, 11:00 AM
I carry the lego blocks and some plywood, we camp mostly in the desert where its soft and very uneven. I get the trailer close to level with blocks, then if one or more jack is too far extended I put a couple of blocks down first. The trailer is much steadier if they're not extended farther than necessary.
