Old 11-11-2015, 10:17 PM   #11
Just put that out there for point of reference. Of course do what works for you.
Grumpy Guy is offline   Reply With Quote
Old 11-12-2015, 05:43 AM   #12
Former Full Timer
Duckogram's Avatar
Originally Posted by dutiful Don View Post
I have done the zero point calibration and it works, but I don't like the way the Auto Mode works. Therefore I need a reference for manually leveling. Plus, the green light has a fairly wide range of acceptance, so if I have everything at my fingertips I can get it level to my satisfaction without having to move around.
I use bubble levels. Here is my left/right. My front/rear is on the bulkhead to the left of the drivers seat.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 11-12-2015, 08:54 AM   #13
StephanFR3's Avatar
Is you level marked in degrees?
StephanFR3 is offline   Reply With Quote
Old 11-12-2015, 03:05 PM   #14
Former Full Timer
Duckogram's Avatar
The carpenters level I used to calibrate zero point and the torpedo level used to verify the top of the monitor for setting the bubble level have no degree marks.
The bubble level, pictured above, has bubble end marks. There is a little "slop" from end to end so anything inside the lines is considered di minimus or in basic terms, close enough for government work.
Old 11-16-2015, 12:48 PM   #15
Just a thought...there is a great level app for your smartphones...one less thing to haul around.
Buckeye Traveler is offline   Reply With Quote
Old 11-16-2015, 07:51 PM   #16
Former Full Timer
Duckogram's Avatar
I have that for my iphone. Its called Johnson's Bubble Level.
Having a hard time keeping it calibrated with all the ios updates.
It gives degrees along with the bubble and you can set it for percent and metric values.
Then you have to have a known level spot to set the phone on in order to use it. Not as convienient as anticipated.
Old 11-23-2015, 08:05 AM   #17
PeteAndEd's Avatar
Though it could end up the same you are really leveling the ammonia powered fridge.
Using the floor of the the freezer as the reference point.
I was told leveling is important for proper slide operation as well.
FR3 2015 30DS
PeteAndEd is offline   Reply With Quote
leveling
