Old 12-02-2018, 09:30 AM   #1
Capt6pak's Avatar
linoleum flooring in 30ds
I just noticed that some parts of the flooring in the main living area seems to be separated from the subfloor, meaning when i walk on it or touch/push on it there seems to be a gap and is noisy when i walk on it. kinda like the glue has released.
the dealer suggested that it was a floating floor covering. Not sure I'm buying that, due that it is not like that in other places.
any thoughts or experiences with this issue
2018 FR3 30DS
1997 and 2018 Wrangler
Capt6pak is offline   Reply With Quote
Old 12-02-2018, 01:18 PM   #2
leisurelarry's Avatar
2015 30DS, mine did the exact same thing when new. Two different spots in the main living area. The dealer did something to fix it end it has never happened again.
leisurelarry is offline   Reply With Quote
Old 12-02-2018, 01:49 PM   #3
Capt6pak's Avatar
if you can remember let me know so i can have them do it, or if its something i can do.
2018 FR3 30DS
Old 12-03-2018, 02:16 PM   #4
Jim Wiemels's Avatar
We have a 2016 FR3 30DS with 42,200 miles and 2 years ago had air raising the floor while driving in strong winds. At that time RV service improved the sealing around the engine cover which seemed to correct the problem until the situation reoccurred this pst summer. It is now at a RV repair shop and I am having them check it again.
Jim Wiemels is offline   Reply With Quote
Old 12-04-2018, 01:25 PM   #5
floor covering
Yes while we were out on the road this past summer we noticed bubbles in the flooring. When we returned home we took to RV dealer and they were able to repair the flooring. It look really nice now. Don't know what caused it.
LinCarol is offline   Reply With Quote
Old 12-05-2018, 11:04 AM   #6
Wolverine 1945's Avatar
There is no such thing as Linoleum any more !!!
Has not been in Many Years !!!
Vinyl Flooring !!!
Wolverine 1945 is offline   Reply With Quote
Old 12-05-2018, 06:37 PM   #7
Vinyl Flooring !!!
Imitation wood.
OldGunny
2016 FR3 30ds
OldGunny is offline   Reply With Quote
Old 12-06-2018, 10:38 AM   #8
Originally Posted by OldGunny View Post
Imitation wood.
Linoleum was outlawed many years ago because it contained asbestos !!!
I sanded many square feet,,, some times while smoking,,,Not Smart !!!
Old 12-07-2018, 07:04 PM   #9
Capt6pak's Avatar
I will check next time we are on the road to see if it gets air under it while driving.
2018 FR3 30DS
Old 06-21-2019, 06:17 PM   #10
Technorick's Avatar
So my concern is what is causing the white powder like stain on the floor almost directly under the living room vent. The carpet runner does not have a backing and there are no leaks in the vent. The stain appears when we open the living room slide. I think the stain may be caused by moisture while the slide is closed. Like in the gap in space between the floor surface and the bottom of the dinette under the storage bin?
We open the slide an clean the white off the flooring. Close the slide and store for a few weeks and then it reappears when the slide is reopened. It comes back.
Technorick is offline   Reply With Quote
floor, flooring
