Old 10-22-2018, 06:49 PM   #1
Jim Wiemels's Avatar
Location of fuse for passenger dash cigarette lighter:
I successfully have blown the fuse on both dash cigarette power outlets. I know the driver side outlet is a 20 amp fuse located in the engine compartment (number 22) per the Ford F53 owners manual. Iíll pickup a new fuse tomorrow. I have no idea where the passenger power outlet fuse is located. We are currently 1,300 miles from home and looking for help. Thank you.
Jim Wiemels is offline   Reply With Quote
Old 10-22-2018, 07:09 PM   #2
FR3Traveler's Avatar
Just looked at mine and there is a 7.5 Amp fuse under the dash just sitting loosely on the board. There is also a 2nd 7.5 Amp fuse which is probably for the drivers side, but could not easily follow the wire back to the Aux. Power Outlet.
Mark & Connie
FR3Traveler
2017 FR3 30 DS
2006 GMC Canyon (toad)
FR3Traveler is offline   Reply With Quote
Old 10-22-2018, 11:25 PM   #3
rk06382's Avatar
I blew the fuses on both 12 volt outlets in the dash also with my Garmin RV 770. I opened the dash (6 screws) to find the fuses. They are two 7.5A inline fuses.
See pictures: (The dash panel is turned over to work on)
I tighten-up the both outer-casings that were loose. I hope that is the reason the fuses blew. I also think 7.5A is to small for a 12 volt outlet. I replaced it with a 15A fuses as they are on a 12 AWG wire.
Robert
2018 FR3 28DS
Samlex EVO-2212 Inverter/Charger | 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 1KW Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads
Retired: Alaska Army NG
rk06382 is offline   Reply With Quote
Old 10-23-2018, 06:53 AM   #4
Fuse replacement earlier thread
There was a thread on this very subject started 9/12/18. We had a similar problem with both dash outlets blowing due to our fast phone chargers on Samsung Galaxy s8 phones apparently drawing too much juice (?). Here is a link to the older thread, hope this works!
12 volt outlet on dash fuse replacement
jimlitwin is offline   Reply With Quote
Old 10-23-2018, 09:36 PM   #5
I keep blowing the inline fuse on drivers side using the Garmin GPS. Not sure why they blow, seems random, but I did wonder if it was when I hit a bump in road.
Anyway I would suggest you pull out dash (six screws) find the inline fuse and untangle and stretch the wires so the fuse can be reached from under the dash. I relocated mine so it is easy to locate and bought a box of 15 amp fuses. Have replaced many so far. Must be the GPS unit as passenger side, wife's cellphone etc. has not blow a fuse yet. Pain in the neck but the only other thing to do is put in a heavier fuse which I am not comfortable doing.
cariboo camper is offline   Reply With Quote
cat, fuse, light, location
