06-21-2016, 09:53 AM
2015 FR3 25DS
Loose dash
[/SIGPIC]
2015 FR3 25DS
2007 Jeep Rubicon (carried)
You just have to get your hands dirty sometime...
06-21-2016, 11:17 AM
Originally Posted by AngioTech55
Wow. What year is this? My 2016 32DS center console shakes likes the devil in winter. And if yours is the same, it would not surprise me this is the cause of it. That vibration in the cetner console is not good for anything, radios, connections and so forth.
On the bottom of my center console I installed a couple of wooden supports to stabalize the console. I think personally, the console is a design flaw and would not surprise me if it cause or HELPED cause this situation.
Sadly, I have no idea how to help you fix it, never explored that territory before. If you do get it fixed, support your center console some how.
06-21-2016, 12:01 PM
On a previous MH I used several short wood screws with large enough flat washers to cover both the fiberglass front cap and the dash where they meet. The screws were installed in the dash underside (short enough so not to penetrate top covering). There was no lip to use any adhesive. Gained access through hood. Yes, this a jury rig approach but it held up for 6 years and still intact when sold. Typically, there is a fair amount of expanding foam on the underside and perhaps something like that would also work to secure it. If there is a lip that your dash sits in then perhaps clear silicone adhesive might work. Numerous ways to correct without going to a dealer.
06-22-2016, 05:42 PM
2015 FR3 25DS
This is a 2015 FR3DS. Truly an epic fail on forest river's part. The dealership won't fix it and it's not covered by the warranty. I'll have to figure a way to secure it myself.
[/SIGPIC]
2015 FR3 25DS
07-02-2016, 02:52 AM
Wayne and sherry are you having any luck with a class action
07-02-2016, 10:14 PM
Dash fix.
I have had many things to fix or repair on our 2014 FR3 28 that we bought new. It’s been frustrating but there is always a fix or work around and the warranty took care of it. Attached are some pictures of the dash fix. Our dealer put two mounting screws through the dash to hold it down from bouncing. They caped them off with color matching caps over the screws to polish it off. Fixed that problem. I also added a cut out designed board to fit under the dash extension that holds the radio, no more bouncing. All problems solved for this fix. Hope this helps.
07-07-2016, 04:14 PM
What do those screws go into?... I've got the same problem with my 2015 30DS... we just about lost our minds with the bouncing and rattling our dash was going through... serious problem. It in fact shook so much that our camera monitor shook loose.
2015 FR3 30 DS
1995 Wrangler
Miles 9100
Days Camped 74
07-07-2016, 05:55 PM
Class Action
My heart is with the folks who are having problems. There is no way that a class action suit is going to happen. Being an old attorney who has a fair amount of experience with Class actions this is a waste of time and maybe money. First, I'm not a fan of many attorneys. If u really have an issue that is worthy of Litigation u are far ahead by filing multiple Small Claims suits to rectify issues. I do not know where u live but can file in Indiana up to $ 6,000 per issue (this is where Forest River Resides). If your grievance has merit u will prevail. Si
mple is always better !
Bear
07-07-2016, 06:11 PM
It is my understanding that there is a wood brace under the dash panel. Anyhow thats what my dealer told me. They just screwed into it and capped the top off to match the dash color. It fixed the bounce problem.
07-07-2016, 06:44 PM
Curiouser and Curiouser
Wooden Brace
We took a piece of the 1.25" dowel left over from the fix suggested for holding the magnet on the overhead bed up tight against the magnet on the ceiling and put 1.25" rubber caps like you would put on a chair leg on each end. We wiped it down with dark Old English so that it matches the wood in the motorhome We didn't worry if the dowel was slightly too short as quarters work great as spacers. We then purchased a square rubber pad like you would put under a chair leg to keep the dowell from slipping around on the motor cover. We put one end of the dowel in that and one end tight up against the wood panel on underside of the radio area. It works great, cost essentially nothing, was easy to do, and now we always have a couple of quarters with which to make an emergency phone call!
07-07-2016, 06:47 PM
By fixing the bounce problem, did that also stop some of the rattling noise from the dash area?...
For the life of me, I can't pinpoint where the major rattling is coming from. sometimes I think it's from down by the windshield where the vents are for the defrost and sometimes up closer to the plastic dash...
It kills me that I can't find it.
2015 FR3 30 DS
1995 Wrangler
Miles 9100
Days Camped 74
07-07-2016, 07:22 PM
Yes it did. Had the same problem with noise around the dash area and couldn't figure out where it was coming from. By screwing the dash down and using a support under the extended part of the dash that holds the radio, all the problems of bounce and noise has stopped. I can now play CD's without them skipping.
07-11-2016, 03:51 AM
Mr J. Is there any chance you could brake out your tape measure and give a ruff location of the screws that your dealer put in to hold down the floppy dash issue? Also do you know what type of screw they used and how long the screws are? Thank You for any info you can give.
07-11-2016, 08:41 AM
I just tried a possible fix, won't know if it will work until I go out this week.
I purchased a small pedestal Jack that you normally place under the step of your rv. It's basically a step saver that I placed between the floor and the dash board to keep it from banging when hitting potholes and such.
Will get back to you all on how it worked.
07-11-2016, 08:46 AM
My unit is in storage right now and is about 10 miles from my home. But here is what I can remember. I have two screws that are evenly spaced from the passenger side to the drivers side. I believe they are about 1 1/2" in from the edge. The screws are I believe 3" wood deck screws, they put the screw thru some kind of a metal cap holder so the cap cover would snap on. If you raise up your dash and put your hand down under it you can feel the wood brace, that will give you some kind of ideal where the wood brace is. If it is like everything else FR does not all units are build the same. Cheaper to check before you drill a hole in the dash. Camping World did the work for me so you might be able to get the cap and cap holder from them. Hope this helps. Good luck, it made a worlds of difference.
07-11-2016, 02:10 PM
I would love to have my service/warranty center do something as permanent and sophisticated as setting screws into the dash. Unfortunately, my service/warranty center is out of their element if it's something more complicated than refilling LP. So I went with the temporary but doable pillars holding things up. It's worked well enough for me, at least for now.
07-11-2016, 03:19 PM
Hi Jim/ I did buy the 2014 FR3. U might remember I live in Indy (Northeast). Like to get together for chat. Cell # 317-432-9178
Bear
07-17-2016, 08:17 AM
Very good Mr J thank you!!
