Old 08-19-2015, 01:37 PM   #11
Problem was fixed by dealer. Cables were out of tol. and needed adjusted. Just a note, warranty is only a year from purchase, after that the dealer said it would cost around $1000 to have them adjusted. Purchasing the extended warrant does not cover this problem.
Mr J is offline   Reply With Quote
Old 08-19-2015, 08:20 PM   #12
fpo1123's Avatar
A thousand dollars to turn a couple of nuts? I don't think I would go back there.. I opened the cover over the pop out (5 screws) and the cable adjusters are all marked as to where they go.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
Old 08-19-2015, 10:16 PM   #13
I agree with you. I find it disheartening that a dealer would charge someone that much for no more then is required to adjust the cables. I just finished watching the video of how to replace and adjust the cables. A piece of of cake to make the adjustments or cable replacements. thanks for your help and pointing me in the right direction.
25ds, slide
