Old 04-30-2016, 08:26 AM   #11
Just picked up my new 2016 27dbh I went to drain the low point drains and they won't turn don't want to break them I was able to drain all faucets and hot water tank and flush then will this be good enough to use ?
allmine4x4 is offline   Reply With Quote
Old 04-30-2016, 08:27 AM   #12
Name:	ImageUploadedByForest River Forums1462022872.179448.jpg
Old 04-30-2016, 08:38 AM   #13
Ford Idaho's Avatar
Originally Posted by allmine4x4 View Post
Crescent wrench and channel locks.
Some one jut put the caps on to tight.
I would and do make the effort to drain out as much water as I can between trips.
Old 05-03-2016, 11:30 PM   #14
b1barnes's Avatar
I added Ĺ inch plastic valves on the end of the connections for both tank and low point drains. Put the ones with the big red handle.
Oh so easy now.
b1barnes is offline   Reply With Quote
Old 05-19-2016, 07:36 PM   #15
FuzzymanCO's Avatar
Could I get the part number for your drain plugs? and maybe where you purchased them? Thanks
FuzzymanCO is offline   Reply With Quote
Old 05-19-2016, 08:20 PM   #16
Technorick's Avatar
Commonly found in the pvc plumbing section of Home Depot.
2014 FR330 DS
Technorick is offline   Reply With Quote
drain
