04-09-2016, 05:48 PM
Low Point Drain ?????
Just picked up my FR3 and due to the weather I have not been able to acclimate myself to the exterior.
Does the low point drain have a Petcock or a nylon plug, if so is it located on the right side undercarriage by the low point drain decal. Thanks for reading the newbie question.
04-09-2016, 05:50 PM
Should be plugs on low point drains and should be located by decal. Petcock would be on your fresh water tank drain. That's the way it is on the 38FL.
Good luck,
Don
Don and Michele
3 Adult Children - 5 Grandchildren
Present campsite - future homesite
04-09-2016, 06:16 PM
On my 2016 30ds there are three drain tubes under the coach located at the low point drain decal. One, with no cap but a screen mesh on it, is the fresh water overflow, another is the fresh water drain that is capped with a pvc fitting, and the third is the low point drain also with a pvc cap on it.
04-10-2016, 08:39 AM
Thank you very much
04-10-2016, 08:47 AM
Additionally, if you only have one low point drain line and if you set your winterization water heater valves to the winterization configuration you will drain both the cold and hot water lines. Otherwise only the cold water line will be drained. Just a thought. This is the set up in the Georgetown 378. If you have two low point drains (1 hot/1 cold) then this info is useless.
04-10-2016, 07:09 PM
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
Days camped 2018 136
04-10-2016, 10:34 PM
Where are these low point drains located? I checked underneath by the decal on the right rear
04-11-2016, 09:23 AM
Drains
edmo, the drains on the 30DS are under the water pump cabnet in front of the water heater. There are 2 plugs to remove.
04-11-2016, 01:11 PM
Thank you
04-13-2016, 11:16 AM
Great idea!!
04-30-2016, 08:26 AM
Just picked up my new 2016 27dbh I went to drain the low point drains and they won't turn don't want to break them I was able to drain all faucets and hot water tank and flush then will this be good enough to use ?
Barry
04-30-2016, 08:27 AM
Barry
04-30-2016, 08:38 AM
Originally Posted by allmine4x4
Crescent wrench and channel locks.
Some one jut put the caps on to tight.
I would and do make the effort to drain out as much water as I can between trips.
05-03-2016, 11:30 PM
I added ˝ inch plastic valves on the end of the connections for both tank and low point drains. Put the ones with the big red handle.
Oh so easy now.
05-19-2016, 07:36 PM
Could I get the part number for your drain plugs? and maybe where you purchased them? Thanks
05-19-2016, 08:20 PM
Commonly found in the pvc plumbing section of Home Depot.
2014 FR330 DS
