Old 02-09-2016, 12:05 PM   #1
Low Point Drain issue
Hi Everyone,
We have a 2016 FR3 30DS and loving it so far. I have taken it out three times so far and have had the same issue each time and wanted to see if anyone else has had this issue.
Up arriving at our site, I will turn off the water pump, and hook up the city water line. In the morning we are greeted to a large puddle of water leaking from the Low Point Drain. I will typically turn the water pump on, and drain water from the fresh tank until the leak stops. After that I won't have an issue for the rest of the camping trip. I should mention I do not have this issue if I do not hook up the City line. The dealer took a look at it and said they do not see any issues with the water lines.
Has anyone else experienced this and perhaps solved it? Any input is greatly appreciated. Thank you!!!
timo123z is offline   Reply With Quote
Old 02-09-2016, 12:21 PM   #2
AquaMan's Avatar
Are you sure it's a low point drain and not the fresh water tank drain? The problem may be that your back flow valve is stuck open and the city water is filling up your fresh water tank. It may also be filling up your tank and coming out the vent tube. Does this drain have a cap on it? Does the cap have the rubber seal inside it. Sometimes when draining the lines the seal will stick to the line and not come off with the cap, then when draining it will fall off line and become lost if you don't know to look for it.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-09-2016, 12:31 PM   #3
Hi AquaMan
This drain does not have a cap on it. It looks like it is just wrapped with black tape. I am assuming it is the Low Point Drain as it is located right where the outside label is.
Old 02-09-2016, 12:39 PM   #4
from Cali
RV Pilot's Avatar
It sounds like the freshwater tank overflow hose. Mine is a clear plastic hose that comes out the bottom at the Lowpoint sign. The black electrical tape holds on a small screen to keep the critters from climbing up into the tank. I'm currently replacing my tubing with some added loupes to prevent the overflow from siphoning my fresh water tank.
______________________
2015 FR3 30DS
2014 Jeep Rubicon X
Central Coast of California
RV Pilot is offline   Reply With Quote
Old 02-09-2016, 12:46 PM   #5
AquaMan's Avatar
Originally Posted by timo123z View Post
Hi AquaMan
Is this the only drain tube without a cap? What color is the tube? Your low point drains will most likely be blue and red. The low point drains may not have caps on them if you have valves located inside a cabinet. If we know exactly which line we're talking about, I'm sure we'll have a fix for you.
Old 02-09-2016, 03:24 PM   #6
I'll take a photo and post it tonight or tomorrow.
Old 02-09-2016, 05:51 PM   #7
from Cali
RV Pilot's Avatar
Name:	ImageUploadedByForest River Forums1455061810.196798.jpg
There should be three outlets. Two are capped. The open one is the drain overflow. Here's what mine look like I took it out today to replace it.
2015 FR3 30DS
2015 FR3 30DS
2014 Jeep Rubicon X
Old 02-09-2016, 09:11 PM   #8
Pretty sure it is the fresh water tank overflow. I had the exact same problems as timo123z. The clear hose is 1" so I just bought 3/4" clear hose and pushed it inside the 1" hose. I then looped the 3/4" hose higher and secured it to the motorhome. Problem fixed. Since there is no water pressure in the hose I just taped the two hoses together after I inserted the 3/4" in the 1". Probably did not even need to tape it.
FR3 Don is offline   Reply With Quote
Old 02-10-2016, 07:29 PM   #9
As FR3 Don and and RV Pilot stated, this looks to be the tank overflow hose, it is the taped hose in the photo. What I don't understand is why it only happened one time on each trip. Once I drained some of the water from the tank, it would not happen for the remainder of the stay (2 additional days each time).
Old 02-10-2016, 09:57 PM   #10
tpatino14's Avatar
I have an FR3 28ds and what I've experienced is the caps on the other two just need tightening and the leaking stops. Only time I had water come out the third was when a friend connect the city water to the fresh water tank instead (wrong connection) and overflowed the fresh water tank as I didn't think to double check his work.
2015 Forest River Forrester Class C2250
tpatino14 is offline   Reply With Quote
drain
