Old 09-07-2014, 07:11 PM   #1
Low Pressure When Flushing Toilet
The water flow when flushing the toilet has gotten noticeably lower. This is true whether connected to city water or pumping from the fresh water tank. I just noticed this problem. Water flow from sinks is fine. Anyone else had and fixed this problem?
Thanks.
_______________
Austin, TX
2014 FR3 30DS
hillcountry is offline   Reply With Quote
Old 09-07-2014, 07:13 PM   #2
Yes. Clean out the filter in the foot valve and you'll be flushing with the best of them in no time.
cucamelsmd15 is offline   Reply With Quote
Old 09-10-2014, 06:42 PM   #3
How do you clean out the filter?
tracyp is offline   Reply With Quote
Old 09-10-2014, 07:45 PM   #4
Fulltime family RVer
I'd try uninstalling it and flushing it both ways with water.
Old 09-10-2014, 08:03 PM   #5
You will have to remove the valve, disassemble and clean the debris out of it.
Old 09-11-2014, 07:13 AM   #6
Yes. There is a bayonet mount where the water line comes into the toilet. Remove the water line and depress the bayonet fittings to get the filter assembly out.
Old 09-13-2014, 11:16 PM   #7
Rolling Magic's Avatar
Ya, been having this problem. Took it twice to fix. Warranty expiring soon, so will need to fix my self!
Rolling Magic is offline   Reply With Quote
Old 03-12-2015, 06:45 PM   #8
Well it happen again, almost no water flow. So I youtubed Dometic 300 toilets and found a video on exchanging the water valve attached to the foot pedal. Well it was easy to disassemble. Turns out the screen inside the valve was clogged with filter carbon from my outside water filter. I blew the accumulation out replaced it and it's flushing like a champ. Wife is happy!
Old 03-13-2015, 11:10 AM   #9
HAPPY WHEN RV'ING
drivmsafe's Avatar
Just a FYI. Dometic was having problems with their 300 toilets early on and was replacing quite a few of them. There was some chatter on this forum regarding it a few months back. Not sure exactly which ones but, you might want to check with them. FR warranty mgr. may be able to help with this also.
I had to have my valve replaced, under warranty, and so far it's working ok.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 03-13-2015, 11:17 AM   #10
Kaadk's Avatar
The problem with the 300's was a leak between the bowl and the black tank. Basically your 'stuff' wasn't going where it was supposed to be going resulting in some major stinking.
Old 03-13-2015, 11:20 AM   #11
Might consider the possibility of just leaving the screen out.
pressure
