Old 10-08-2014, 12:49 PM   #11
niedobry1's Avatar
Did you order sku#1169? If not what did you order so the bottom of the base aligned with the existing holes? Thanks for your help.
Gil
niedobry1 is offline   Reply With Quote
Old 10-08-2014, 01:20 PM   #12
Yes, I ordered SKU # 1169 from RVSurplus. The base hole pattern is standard and aligned exactly with the existing holes. Remember to disconnect the seatbelt receiver and strap connection from the existing seat, before unbolting from the floor, I also used blue Loctite on the seatbelt bolt, but it probably isn't needed.
Albert1950 is offline   Reply With Quote
Old 10-08-2014, 02:34 PM   #13
niedobry1's Avatar
Thanks for quick reply
Old 10-17-2014, 12:47 PM   #14
niedobry1's Avatar
New pedestal is installed and the height is perfect, my feet now rest on the floor without cutting off circulation. Thanks for your help. Best regards
Old 10-19-2014, 10:48 PM   #15
The DW loves it as well. Thanks for sharing.
zippyzrx is offline   Reply With Quote
Old 10-29-2014, 02:29 PM   #16
wher in Elkhart ind did you get these--- do you have a contact number I calle a couple of places and they do not have them. are you sure the original was 10 inches, Mine is 8 1/2 and I meed about two and a half less. the pic of the new one looks shorter than the 7 1/2. I am short legged and REALLY get tired of reaching the pedals with my tip toes , can hardly even reach the floor.
thanks
Short legged Larry
Lfrazee is offline   Reply With Quote
Old 10-29-2014, 02:30 PM   #17
please send their contact number and any info that you gave them to get the right ones, want to make sure all bolt holes line if possible.
Larry
Old 10-29-2014, 07:54 PM   #18
Lowering the seats
Short Legged Larry,
I am sure the original was 10 inches high.
The 7-1/8 inch base is SKU # 1169.
The 5-1/2 inch base is SKU # 1172.
The company name is "Factory RV Surplus"
The contact information is - 1611 W Bristol St, Elkhart, IN 46514 (800) 325-1461 (574) 262-3327
The Web address is www.factoryrvsurplus.com.
Good Luck.
Old 10-30-2014, 08:05 AM   #19
checked mine again measured between the plates and got 7.5 but 10 at top of base plate ---ordering the ones with 1169 sku thanks!!!!!
Old 04-20-2015, 11:17 AM   #20
StephanFR3's Avatar
Bump
StephanFR3 is offline   Reply With Quote
