Old 05-01-2014, 07:02 PM   #1
Lowering the seats
At 5ft 7, I found the drivers seat a little uncomfortable, so I decided to change the seat post.
At 5 ft 4 the my wife wanted hers also lower. Our FR3 came with 10 in post, I bought 7.5 in post from rvsurplus, Elkhart IN. Easy to install, it took about 2 hours.
[ATTACH]Click image for larger version
Albert1950 is offline   Reply With Quote
Old 05-01-2014, 07:09 PM   #2
Looks like an easy mod. Being the cheapskate I am, I would have just cut 2-1/2" or 3" out of the stock ones and re-welded them. Saving the pcs so I could re-weld them back to stock when ready to trade.
Old 05-01-2014, 10:51 PM   #3
Pammyjams's Avatar
Love this mod, and we need it too! Even with a BF who is 6', he wishes he could lower the seats. At 5'4" I can hardly reach the peddles, let alone my feet resting on the floor in the passenger seat!
Pammyjams is offline   Reply With Quote
Old 05-02-2014, 07:37 AM   #4
My wife has the same problem, I put in a piece of styrofoam on the passenger's side with a carpet on top. It is perfect, her feet touches the floor...all is good.
johnpisue is offline   Reply With Quote
Old 05-02-2014, 09:10 AM   #5
Just ordered mine...
Thanks for the info. Just ordered one. $50 and $27.90 for shipping (ouch). Wife said she could make due with it the way it was, but that meant I should make the change. I'll save the old one for when I sell or trade in my FR3 DS25.
My wife was going to get some Garden Kneelers from the Dollar Store and glue them together. But a lowered seat will be perfect.
2014 FR3 25DS (Bought 2-22-2014)
Spokane, WA
wjpelka is offline   Reply With Quote
Old 05-02-2014, 09:17 AM   #6
Originally Posted by wjpelka View Post
...Wife said she could make due with it the way it was, but that meant I should make the change...
Wise man. You have figured out one of women's idiosyncrasies.
Old 05-02-2014, 11:16 AM   #7
Torque setting
The nuts holding the four bolts per seat have nylon inserts. I didn't measure the torque when removing them, although I wish I had. I was easily able to loosen them with a 3/8 ratchet and 3/4 deep well socket.
If anyone has Ideas on what the torque should be, please share.
Old 05-02-2014, 11:44 AM   #8
IF I remember...
Once I get my pedestal and change it out, I will try and remember to get that value. I hadn't even thought about that but it should be a good idea. I might have some new nylocks around the house and replace the. You might go to the drivers side and break one nut free with the torque wrench. Then you'd have the value...
Spokane, WA
Old 05-04-2014, 09:50 AM   #9
StephanFR3's Avatar
Do they make a pedestal with adjustable height?
StephanFR3 is offline   Reply With Quote
Old 05-04-2014, 12:49 PM   #10
HAPPY WHEN RV'ING
drivmsafe's Avatar
Check out this link.
Seat Hardware, Glastop RV Seating
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 10-08-2014, 12:49 PM   #11
niedobry1's Avatar
Did you order sku#1169? If not what did you order so the bottom of the base aligned with the existing holes? Thanks for your help.
Gil
niedobry1 is offline   Reply With Quote
Old 10-08-2014, 01:20 PM   #12
Yes, I ordered SKU # 1169 from RVSurplus. The base hole pattern is standard and aligned exactly with the existing holes. Remember to disconnect the seatbelt receiver and strap connection from the existing seat, before unbolting from the floor, I also used blue Loctite on the seatbelt bolt, but it probably isn't needed.
Old 10-08-2014, 02:34 PM   #13
niedobry1's Avatar
Thanks for quick reply
Old 10-17-2014, 12:47 PM   #14
niedobry1's Avatar
New pedestal is installed and the height is perfect, my feet now rest on the floor without cutting off circulation. Thanks for your help. Best regards
Old 10-19-2014, 10:48 PM   #15
The DW loves it as well. Thanks for sharing.
zippyzrx is offline   Reply With Quote
Old 10-29-2014, 02:29 PM   #16
wher in Elkhart ind did you get these--- do you have a contact number I calle a couple of places and they do not have them. are you sure the original was 10 inches, Mine is 8 1/2 and I meed about two and a half less. the pic of the new one looks shorter than the 7 1/2. I am short legged and REALLY get tired of reaching the pedals with my tip toes , can hardly even reach the floor.
thanks
Short legged Larry
Lfrazee is offline   Reply With Quote
Old 10-29-2014, 02:30 PM   #17
please send their contact number and any info that you gave them to get the right ones, want to make sure all bolt holes line if possible.
Larry
Old 10-29-2014, 07:54 PM   #18
Lowering the seats
Short Legged Larry,
I am sure the original was 10 inches high.
The 7-1/8 inch base is SKU # 1169.
The 5-1/2 inch base is SKU # 1172.
The company name is "Factory RV Surplus"
The contact information is - 1611 W Bristol St, Elkhart, IN 46514 ē (800) 325-1461 ē (574) 262-3327
The Web address is www.factoryrvsurplus.com.
Good Luck.
Old 10-30-2014, 08:05 AM   #19
checked mine again measured between the plates and got 7.5 but 10 at top of base plate ---ordering the ones with 1169 sku thanks!!!!!
Old 04-20-2015, 11:17 AM   #20
StephanFR3's Avatar
Bump
