Old 02-06-2014, 06:25 PM   #11
Ford Idaho's Avatar
Originally Posted by PhotoMaster View Post
I just happened upon this thread. We had 2/3 of a tank (on the tank gauge) when we spent one very cold night (19F) and had heat set at 70F. By the next morning we were down to 1/3 of a tank. I know the heat ran a lot, but that sounds way excessive. This is on a 2014 FR3 30DS.
What if anything was the water heater and fridge running on?
If gas this would all add up quick.
Old 02-06-2014, 07:33 PM   #12
Motoring
grotto69's Avatar
Thank you sir for asking! :-)
I am a new RV'er and wanted to know how far would my LP would last in temps below 32 degrees.
Running heat in lp and water tank on lp
Everything else on electric
How many weeks would lp last?
grotto69 is offline   Reply With Quote
Old 02-06-2014, 07:57 PM   #13
2007 WildCat 32QBBS
05CrewDually's Avatar
My father was a full timer for one winter in his Montana 5er. In freezing cold weather he would go through one tank every other day. He kept the thermostat high around 70. If you want it to last longer, turn it down to about 65 at night.
05CrewDually is offline   Reply With Quote
Old 02-06-2014, 10:31 PM   #14
That does sound like a lot. I've been running my furnace every night and sometimes during the day for 10 days since I last got it filled and it' still showing 2/3 (true it's on the control panel... I'll have to check the gauge). Still 1/3 of a tank in one night, even a cold one, sounds excessive. According to typical numbers I've seen (from my post above), even if it ran steady for 8 hours that should be less than 3 gallons. Of course, I don't know exactly how good those numbers are. Someone else might have a better idea.
Barbara
BarbaraG is offline   Reply With Quote
Old 02-07-2014, 09:44 AM   #15
Rolling Magic's Avatar
For one week I had my set at 64 and it took about 1/4 of a tank. Outside evening temps at the time were 32 degrees. Go figure...
Rolling Magic is offline   Reply With Quote
Old 02-07-2014, 07:13 PM   #16
I just checked my LP gauge... I'm at 1/3 tank even though the inside monitor shows 2/3. It must be right on the edge of tripping down to the next level. I've been running the furnace at between 68 and 70 at night, higher in the morning and evening when I'm still up, for 11 nights since filling up. The night temperatures have been mostly in the high 40's; a few in the 30's, a few in the 50's. I paid $4.15 a gallon; 2/3 of 24 is 16 (is it 2/3 or 24 or of 20, not sure about that?). Probably should start using the electric heater a little more since the last eleven nights have cost me ~$65. Hmmm...
Old 02-07-2014, 08:41 PM   #17
2007 WildCat 32QBBS
Unless your gauge works off of a scale that monitors the weight of the bottle, it's not accurate. Don't rely on them or it could be a cold night. Even chassis mounted LP tanks the gauge is not entirely accurate.
Old 02-07-2014, 08:48 PM   #18
I'm confused. I thought the whole point of the gauge on the bottle was to give a more accurate measure of the amount of propane remaining. Sounds like you're saying these gauges aren't accurate. How, then, are we supposed to know how much propane we have?
B
Old 02-08-2014, 07:51 PM   #19
We went through about 1/4 of a tank with the heat on 68 a few weeks ago. Granted, it was 20* outside.
The gauge is based off of pressure IIRC, so dont rely on it. It will read less when cold, more when warm.
For reference, the furnace in a friends toter is also a 35k btu, and it will burn 1/2 gallon of propane per hour running constantly. Most wont run constantly, but cycle on and off. When we camped a few weeks ago when it was 20*, Id say it was running about 40 minutes out of every hour or so.
The other mitigating factor is whether your Dometic t-stat is set to D1 or D2, because that has a major impact on how long the furnace will run.
The fridge and water heater use very minimal propane. The fridge would run something like a few months on the propane supply, water heater probably about the same. A gallon of propane should last the fridge about 5 days, probably about the same for the WH.
cucamelsmd15 is offline   Reply With Quote
Old 02-09-2014, 01:03 AM   #20
PhotoMaster's Avatar
The fridge was on shore power and the water heater was off. (RV was winterized)
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
