Old 03-24-2018, 02:13 PM   #1
Lug nut size
2014 FR3 30DS
Can someone tell me what size socket for the wheel covers and lug nuts if different?
reverand2000 is online now   Reply With Quote
Old 04-03-2018, 01:46 PM   #2
Bump
Can't anyone tell what size lug wrench is needed for hub cap and wheel?
Old 04-03-2018, 02:09 PM   #3
bubbles's Avatar
Don't have an FR3 but are the wheels 19.5 or 22.5? I think the 22.5 socket size is 1 5/16 and the 19.5 may be the same just smaller studs. This is for the actual lug nuts. I'm not 100% on this so it may be a moot input.
Old 04-03-2018, 03:50 PM   #4
Thanks. They are 19" wheels. The lug wrench/socket size is what I am looking for.
Old 04-04-2018, 01:57 PM   #5
Wheels are 19.5
Hub cover socket size is 1-1/8 (see picture). No torque specified. Please note only 3 are actual lugs.
Wheel has 10 lugs. Size 13/16. Specified torque on those is 150 lb-ft. See attached picture, make sure you get a deep socket for those
ID:	167214   Click image for larger version
DutchRv is offline   Reply With Quote
Old 04-04-2018, 02:55 PM   #6
Thanks Dutchrv. That's what I was wanting. I had tried 1 1/8 but will try again. Picture shows it should work.
Old 04-04-2018, 03:09 PM   #7
You're welcome!
Please make sure you try to take off the 3 actual lugs. Please note the indents in the lugs compared to the 'fake' ones. Tap on them with the socket to hear the difference too (solid vs. hollow).
