Old 08-02-2014, 08:47 AM   #1
Media panel and TV hookup
I cannot get the cable to play on my main TV without running a cable directly to the TV. I have plugged cable into input in aft storage bin but TV comes up no signal. I took the panel off by the main door and ran the cable input line to TV and got all channels. Outside TV only works with free air signal. When I direct hookup the speakers overhead still work? I have also direct run the cable from a tailgater Dish antennae to the Dish receiver and then had to connect the HDMI cable to get video. The audio worked through the media center control but no video unless I used the HDMI cable. Outside TV does not work with satellite either. Anyone else having issues??
Semperfi1961 is offline   Reply With Quote
Old 08-02-2014, 09:06 AM   #2
harpman's Avatar
I had an issue just mounting..so I let the dealer mount it and they also did all the connections..cost was about 50 dollars..time is money...so it was well worth it for me..sometimes what seems to be a simple project turns out taking hours...took the tech about a half hour
831RESS FLAGSTAFF
F150 FORD ECOBOOST
harpman is offline   Reply With Quote
Old 08-02-2014, 10:44 AM   #3
Motoring
grotto69's Avatar
Did you press the little black button above the broom closet ? That toggled between antennae and cable.
grotto69 is offline   Reply With Quote
Old 08-02-2014, 11:06 AM   #4
Thanks guys. The CW tech said it worked but when the cable is connected it doesn't? Free air works fine with the booster button pushed. Guess I'll need to fine a better tech guy to get it right
Old 08-02-2014, 11:36 AM   #5
harpman's Avatar
Make sure your booster is off when connected to cable...booster is only for over the air broadcast..cable won't work with booster on
831RESS FLAGSTAFF
F150 FORD ECOBOOST
