On my 2014 V-10, Ford recommends Ford Motorcraft Synthetic Blend 5W20, Oil Filter is a Motorcraft FL-820-S, Ford P/N F1AZ-6731-BD FL-820S.
Walmart carries 5 qt jugs and then buy another quart. Mines takes about 7 quarts though. Start out with 6 and then top it off.
If you want to make it really easy NEXT TIME, get a Fumoto valve and replace the plug.
Next time all you need is a small hose and a couple of gallon jugs. The oil filter, however, holds oil no matter what you do although it is at least vertical.
