The coax from your park cable connection is a direct run to one of the three connectors on the rear of the booster plate.
The three connectors on the rear of the plate are for park cable input, OTA antenna, TV output 2, the front connector is TV output 1.
Have the tech check the signal by removing the booster plate and determining which coax is from the park cable input.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
