Old 10-16-2014, 08:14 AM   #1
Technorick's Avatar
New or used? What would u do?
So i have a choice between a used 2014 30 DS and a new one for $14,000 more.
I live in New England and am technically handy with electromechanical stuff.
While shopping I've read this entire message board and knew what look for.
The 2014 has only 1200 miles on it being sold as used. The dealer tells me original mfg warranty will not apply as it is not transferable.
The used 2014 Findings.
It's got the 1300 ac not 1500
Its got the original power steps hat will likely break a bolt or pop a rivet.
It's got the bad 300 toilet not the 310. Assuming all 300s are bad?
It's got no shore powered coil Heater element the water heater. IE. no flip switch outside In the panel. This is a feature I've used a lot in my tow behind to save propane.
Remarkably it has the upgraded shower curtain.
Unfortunately carpet in the cockpit and bedroom
No drawers under the dinette but using suggestions hear I can make hinged doors on the top.
No led light upgrade. But honestly as I only dry camp twice year that's not an issue to me.
Unknown chances I take:
Bad bed room slide gears with teeth that will break? Probably.
P trap loop to solve siphon problem. No. But I can easily fit that.
Most importantly the unknown status of the "house" systems. If I buy the used coach and discover other repairs that ,
Many of you had a chance to get fixed under warranty, I won't have A warranty. IE I fear the original owners may not have discovered bad reported and corrected known manufacturer defects.
I know I will upgrade the steps and toilet myself. These are things I will not wait to see if they smell or break. Around approx $1200. What worries me is the slide out in the bed room!
Given these facts.what would you do? Buy new with mfg warranty ? Or buy used without. As I am handy and know what to look for, I'm leaning towards the used coach. And possibly purchasing a n extended warranty whither the savings.
Technorick is offline   Reply With Quote
Old 10-16-2014, 08:29 AM   #2
Mddle of the Rd Extremist
MeepMeep's Avatar
IMHO - unless you're getting a sweetheart deal on a unit that's in really good condition, I'd go with a new one for all the reasons you listed. Dad told me that somebody got rid of that car/truck/camper/motorcycle/etc. for a reason.....and you're going to find out what that reason was AFTER you buy it
Good luck!
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 10-16-2014, 08:35 AM   #3
jonrjen's Avatar
For $14K you could afford to either do or have done most repairs that may come along. The A/C could be up graded for $1K +or- before recouping part of the cost my selling the old unit.
Sounds like you have educated yourself as to what to expect may go wrong. Which means that you also have read some horror stories about dealer service, follow though, and time taken to repair under warranty claims. If you don't have this warranty you would be free to take care of things your self or at least to a repair facility of your choosing.
Or as you mentioned you could purchased an extended warranty.
Another thing about buying used for $14,000 less is that you also save the taxes you would have to pay on that extra $14K for buying new.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 10-16-2014, 08:45 AM   #4
jonrjen's Avatar
Good luck!
I used to feel that same way. However when it comes to RVs and more so motorhomes there are so many that get purchased on the spur of the moment or to fulfill a bucket list dream of the original owner. However, many first time owners don't think a head as to what all is involved in camping, maintenance, a place to park or store the RV, and least of all dumping the black water tank.
Could also be that the original owner found out that the monthly payments that he knew he could handle don't fit into the family budget once numbers on scratch paper turn into numbers in the check book.
Of course, it could also boil down to the original owner did use the RV and got tired of dealing with warranty and or quality control issues.
So it's not really a crap shoot, if you research what you may face in cost/repairs/expectations. But as the saying goes, sometimes a flush beats a full house........at least in the plumbing business end.
2013 Wildcat 353LS
Old 10-16-2014, 09:33 AM   #5
StephanFR3's Avatar
The A/C is held on by 4 bolts and lifts right off though not exactly lite.
The 15000 is just over $650 if you shop. You could save the 13000 for a second A/C in rear. The steps also about $650 also bolts right in. They are same gears in slides. The 14 is a queen bed so less stressful on gears. My theory is though bad design and weak gears the prime problem with the gears is something in the way like folding bed in the 25 or holding the switch to long after hitting end of travel. Test drive the hell out of the used one and if systems work and nothing is broken you might be better off. The real problem is dealers only want to sell new ones and never fix anything. Run the Vin and talk to original owner. Good luck with what ever you choose.
StephanFR3 is offline   Reply With Quote
Old 10-16-2014, 10:17 AM   #6
Technorick's Avatar
The 15000 is just over $650 if you shop. You could save the 13000 for a second A/C in rear. The steps also about $650 also bolts right in. .
Wow I never thought about repurposing the 1300 ac unit in the back! Brilliant! My wife likes it cold in bed! And we are almost always at a 30A park. And it would replace the power fan upgrade I would have done anyway back there.
Thanks....
I'd have to get brave before cutting the hole for the second AC in the back..but I would have the hole from the old unit to use as a template!
Now, what do you suppose the draw of running both ac at once would be?
Old 10-16-2014, 10:34 AM   #7
Iwannacamp's Avatar
Hello. I love the quest for a new RV... it is fun. IMHO A lot of people here complain about service...Some don't I know... It's a crap-shoot on "good vs crappy" dealer and RV... that being said. You will already lose the "beginning" depreciation on the RV, so its already a gain. I bought used and would do it again, but I am TIGHT(almost like a was a depression child). I save where I can and spend where I need to. I feel I got my monies worth when I bought...so I am happy. I might add..the previous owner of mine was OCD...I wasn't scared at all. He told me of two or three issues..and offered to fix, but that meant a week or two to repair and possible "mind-change" from the seller at the reduced price...or a returning counter offer from another buyer. JS
Old 10-16-2014, 10:40 AM   #8
jonrjen's Avatar
Thanks....
Actually, if you now have a vent or power fan in the bedroom ceiling the AC will drop right in that opening with out any further mods required. The run a power cord down and exit through the floor where you can plug in the second AC into the 15/20 amp receptacle next to the 30amp power receptacle and you will be able to run both a/c units while on shore power.
2013 Wildcat 353LS
Old 10-16-2014, 11:05 AM   #9
BamaBob's Avatar
Point to consider:
Buy the used RV, save $14K
Fix all the low hanging fruit (i.e. easy & cheap - like the A/C) - $1-2K
Reserve a spot for FROG Goshen 2015 - say $1K for reservation + fuel ect.
Get Forest River to fix all the big ticket items for *free* at the rally
Pocket the remaining $11Kto be used for future RV trips
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 10-16-2014, 11:05 AM   #10
Warranty
Regarding the warranty, no Forest River warranty is one thing, but I'll bet the Ford chassis warranty is transferable.
Albert1950 is offline   Reply With Quote
