Old 02-24-2014, 09:16 PM   #11
FYI, regular air is 78% nitrogen.
I had a talk with my dealer's service guy. He told me that he asked Forest River if, when mounting the tire new, they evacuate the existing air out of the tire and create a vacuum before filling with pure Nitrogen. The response was no. So they are adding Nitrogen to a tire already full of regular air. IMO, gimmick.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 02-24-2014, 09:16 PM   #12
Originally Posted by davel1971 View Post
air filled tires change pressure with temperature change. Rule of thumb about 1psi per 10 degrees. Nitrogen pressure stays constant regardless of temp.
Noooooooooooooooooooooooope.
PV = nRT
Cant defeat the laws of physics. And your rule of thumb actually applies to N2 filled tires. Air in tires will change about 2 psi per 10 degrees. Ive got, oh, a few gigs worth of data to back this up too.
http://www.tirerack.com/tires/tirete...jsp?techid=191
Overall, nitrogen isnt worth the hassle to put in your tires unless you really enjoy a lightened wallet, or youre using it for a critical application like race tires. Full disclosure, I do use it in my race tires and vacuum them prior to filling with nitrogen simply because it is more reliable and consistent when determining pressure climb in varying conditions. Otherwise, I dont bother with it in anything else.
cucamelsmd15 is offline   Reply With Quote
Old 02-25-2014, 01:18 AM   #13
TxTravelingRN's Avatar
Had it in my Nissan 350Z. Worthless IMO and switched back to air. Got low tires just as often. Supposedly the nitrogen makes the psi more constant in tires regardless of temperature. Didn't find it to live up the hype at all as I frequently had 8-10 change in psi from early cool morning to warmer afternoon.
2013 F350 Lariat 6.7 Diesel DRW
2013 Rockwood Ultralite 2608 WS
2013 Days Camping: 61
2014 Days Camping: 200+
TxTravelingRN is offline   Reply With Quote
Old 02-25-2014, 01:46 AM   #14
Engineer of Crazy Train
ChooChooMan74's Avatar
We use to put nitrogen in the race car tires. Caused less pressure buildup when they heated up keeping the stagger consistant. Of course, we had nitrogen cylinders for the air guns.
Sent from my Samsung Galaxy Note 2 using the FRF mobile app.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 02-25-2014, 02:39 AM   #15
wmtire's Avatar
PV = nRT
I'm not sure I'm following you here. The Tire Rack article states the rule of thumb that tires inflated normally, will have a pressure change of ONE psi per 10 degrees of temperature change.......as copied below:
"Tires are typically inflated with air that’s a combination of roughly 78% nitrogen (N2), 21% oxygen (O2) and 1% miscellaneous gases. And since all gasses expand when heated and contract when cooled, tire inflation pressures rise and fall with changes in temperature by about one psi (pound per square inch) for every 10į Fahrenheit change in temperature. This is one of the reasons it’s recommended that tire pressures be checked early in the morning before ambient temperatures, the sun's radiant heat, or the heat generated by driving causes the tire pressure to rise."
Were you linking to the Tire Rack article to prove or disprove your statement of 2 psi per 10 degrees?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-25-2014, 05:36 AM   #16
Oakman's Avatar
Our Silverback came with nitrogen in the tires and the first two years, including over winter storage, I never had to add air to the tires. I finally had to put a couple of pounds of air in each tire over this winter. If your RV came with nitrogen then enjoy the benefit of not having to air up the tires all the time.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 02-25-2014, 06:22 AM   #17
"Tires are typically inflated with air thatís a combination of roughly 78% nitrogen (N2), 21% oxygen (O2) and 1% miscellaneous gases. And since all gasses expand when heated and contract when cooled, tire inflation pressures rise and fall with changes in temperature by about one psi (pound per square inch) for every 10į Fahrenheit change in temperature. This is one of the reasons itís recommended that tire pressures be checked early in the morning before ambient temperatures, the sun's radiant heat, or the heat generated by driving causes the tire pressure to rise."
Every publication says some form of "about 1 psi per 10 degrees". Thats fine. I have data that shows that its actually closer to two, usually between 1.7-1.8 psi per 10 degree change because those articles always assume two things:
1. Professional installation of tires
2. The air you get from professional installation or the gas station is run through a dryer and is relatively free of humidity (hint: its not, and it isnt).
I was linking to the Tire Rack article because it disproved the notion that nitrogen doesnt change pressure with temperature, and also because they (like most other organizations) think more people would be better off with a tire pressure gauge and a little common sense.
The moral of the story is to simply check the tire pressure, versus spending money on gimmicks such as nitrogen in passenger car tires.
Old 02-25-2014, 06:28 AM   #18
Herk7769's Avatar
The "Nitrogen" Myth has been debunked years ago.
It was a scam run by tire dealers to increase profits. It was SO profitable, that just about everyone now "Offers the Service."
And no, every gas obeys Boyle's Law of Gasses. Nitrogen also expands and contracts when temperatures change. Since a tire's internal volume is constant, changing the temperature will raise and lower internal pressure.
Oh, and the reason Nitrogen is used is NASCAR, Space Shuttle, and Aircraft tires is for crash purposes and no other reason. Those tires STILL explode when heated; they just don't contribute their oxygen to the fire.
HAM CALLSIGN - KC3FFW
Old 02-25-2014, 06:29 AM   #19
Herk7769's Avatar
I was linking to the tire rack article because it disproved the notion that nitrogen doesn't change pressure with temperature, and also because they (like most other organizations) think more people would be better off with a tire pressure gauge and a little common sense.
A big "amen" brother!
Old 02-25-2014, 06:44 AM   #20
The (Nitrogen) comes up every year right after the (Daytona NASCAR Race)! Lots of Members go to the race and get the (Secret) info about the (Nitrogen) then try it for all kinds of reasons,(Speed above 65MPH, better handling out of turn 4,cooler brakes,more MPG,Ect.) The bottom line use (AIR)! Youroo!!
tire, tires
