Old 02-24-2014, 07:17 PM   #1
Motoring
grotto69's Avatar
Nitrogen in Tires
When we bought our FR3 they filled the tires with Nitrogen. Oh no, not another tire post...
Anyone know what the benefit of this is/was? They said smoother ride, I'm not convinced. Also, if I need to top off, can I put air in now, or do I have to stick with Nitrogen.
Your thoughts are appreciated.
Grotto
grotto69 is offline   Reply With Quote
Old 02-24-2014, 07:22 PM   #2
davel1971's Avatar
air filled tires change pressure with temperature change. Rule of thumb about 1psi per 10 degrees. Nitrogen pressure stays constant regardless of temp.
David & Lynn
Old 02-24-2014, 07:22 PM   #3
MagnoliaTom's Avatar
You can add air. Nitrogen allegedly keeps pressure longer and it is drier than air preventing issues with TPM sensors. I have it in my tires and needed to add air after 3 months so I'm not really sold.
2014 Freedom Express 320BHDS Liberty Edition 50th Anniversary
2005 F250 Lariat SuperCrew 6.0 PS Diesel
2004 Excursion Limited 4x4 6.0 PS Diesel
2000 Excursion Limited 7.3 PS Diesel Sold:crying
MagnoliaTom is offline   Reply With Quote
Old 02-24-2014, 07:26 PM   #4
Send a message via MSN to Tiggerdad
Nitrogen has larger molecules and won't leak down as much and that tires will run a little cooler. Problem as I see it, every time you put a gauge to the valve stem you let a tiny amount out and eventually you have to air up again. You then must find a nitrogen station which may be hard to find or use air. Using air will dilute the nitrogen. Air is 78% nitrogen. IMO, a waste of money.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 02-24-2014, 07:26 PM   #5
10x
Nitrogen has a larger molecules structure. So it takes longer for it to leak out of tires and maintains pressure better. Just use air and check pressures every time you go camping.
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 02-24-2014, 07:28 PM   #6
Grape Escape
Just another gimmick to take your$$$$$$. Get 10 more miles per gallon as well........
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 02-24-2014, 07:28 PM   #7
WFD
and it seems a bit silly that they put nitrogen in trailer tires...a little inconvenient to haul the trailer to a tire shop to add nitrogen down the road when they will require it, eventually at some point they will...in my opinion its only beneficial for the first little while of ownership, till that top up is required... concept of nitrogen makes sense, but at least when its done on your TV tires or car tires you can wheel it into a location easily for the top up.
Rick
WFD is offline   Reply With Quote
Old 02-24-2014, 07:33 PM   #8
davel1971's Avatar
Rick
I've always thought same thing. Plus, why are we wasting it in cheap Chinese tires. Keep the nitrogen and give me some quality air filled tires.
David & Lynn
Old 02-24-2014, 08:43 PM   #9
Bobb36's Avatar
I hate when they take my black caps and put on them ugly green ones, oh and I think the nitrogen is worthless too.
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
Bobb36 is offline   Reply With Quote
Old 02-24-2014, 09:03 PM   #10
B47
Whether nitrogen in tires is worth the hassle or not is an ongoing discussion item.
If I might, I suggest the OP do a search of the topic here as there are many points of view and opinions given. One of the threads was started on 12-2010 and there are several more.
tire, tires
