Old 08-18-2018, 01:07 PM   #1
No power! Please help!
This morning , the generator was on ... and I was using the microwave and it went out! So now I have no power to the microwave or the outlet under the table and the gfi in the bathroom wonít reset. We checked the breakers and the fuses in the master bedroom and they are all good.
colourful64 is offline   Reply With Quote
Old 08-18-2018, 01:09 PM   #2
Reset the generator?
Old 08-18-2018, 01:13 PM   #3
The generator works
Old 08-18-2018, 01:15 PM   #4
fonzie's Avatar
Originally Posted by colourful64 View Post
The generator works
Reset breaker on generator, most likely tripped.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 08-18-2018, 01:20 PM   #5
The generator works
I was just wondering if perhaps you overloaded the generator and it went into overload mode, meaning the generator is running but producing no power. Usually you just have to stop and restart the generator to clear, or hit a reset button.
If you did that, then it has to be a breaker or transfer switch.
Old 08-18-2018, 01:54 PM   #6
It was the circuit breaker on the generator! Thank you so much you genius
Old 08-18-2018, 02:12 PM   #7
PPST Wannabe
kenandterry's Avatar
colourful64....
You mentioned you were using the microwave when the power went out.
1. What amperage is your FR3?
2. If it’s 30 amp, I suspect somebody somewhere in your rig turned something else on at the same time, and you tripped the breaker.
3. At 30 amp, DO NOT turn on air conditioners at the same time, or hair dryers, or toaster, or electric water heater, or electric fry pans etc etc etc. Any appliance which is basically a controlled “short circuit” is too much at the same time on 30 amp.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 08-18-2018, 05:16 PM   #8
Edmo's Avatar
Just as an informational, where exactly is the generator breaker located, just in case!
Edmo is offline   Reply With Quote
Old 08-18-2018, 09:13 PM   #9
At the gen itself. Take off cover, on the lower right side of the control panel. Small black toggle switch.
DutchRv is offline   Reply With Quote
Old 08-19-2018, 01:46 PM   #10
Curiouser and Curiouser
Didn't know there was a breaker on the generator. Thanks for the info and location!
Finch
2016 FR3 30DS
Finch is offline   Reply With Quote
power
