Old 09-16-2017, 09:04 AM   #1
No power to house
The generator is running but no power to house. I checked the plug, the breakers, and reset the battery reset button . Check fuses, all are fine. I tested the GFI in the bathroom. It tripped but now won't reset. Any other suggestions?
khsmile is offline   Reply With Quote
Old 09-16-2017, 10:21 AM   #2
ceedog's Avatar
Starting with basics. Did you check the store/use switch?
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 09-16-2017, 10:57 AM   #3
A32Deuce's Avatar
How about the circuit breaker on the generator!
A32Deuce is online now   Reply With Quote
Old 09-17-2017, 06:00 AM   #4
Do you have the plug plugged in to the inverter? Once you unplug from shore that has to plug into the wall of the mh
colourful64 is offline   Reply With Quote
Old 09-18-2017, 08:06 AM   #5
Wolverine 1945's Avatar
By house he means RV right ???
Wolverine 1945 is offline   Reply With Quote
Old 09-18-2017, 08:09 AM   #6
Checked that, all good
Old 09-18-2017, 08:09 AM   #7
No power to house
Yes it's plugged in. Had brain fart once before on that one so I always make sure it's plugged in
Old 09-18-2017, 08:10 AM   #8
Don't know what that is
Old 09-18-2017, 08:11 AM   #9
Yes
Old 09-18-2017, 08:20 AM   #10
Do you mean battery disconnect? If so yes, check that it's on.
power
