Old 01-31-2016, 11:50 AM   #11
Senior Member - Retired
Grotto69 - on my FR GTXL, the valve for the toilet snaps in place at the rear of the toilet, making it relatively easy to remove/clean/reinstall. Had to clean out the screen in the valve two weeks ago after it clogged on the first day of our beach camping trip.
Antone - if you have not done so recently, when you get home you might want to check the anode rod in your water heater. Mine was pretty much eaten away and the resulting debris is what clogged the toilet valve.
Attached is a picture of a new anode rod on the left and my eaten up anode rod the right.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 01-31-2016, 12:28 PM   #12
Antone's Avatar
Thank you for all the info! I did notice decreased flow coming from the toilet valve, so I'll clean that out and check the anode rod as well. We had our FR Cherokee Lite 28A+ TT for 8 years and used the heck out of it, never had to do anything besides tires, brakes, bearings maintenance, we were spoiled I guess. The moho has been a new learning experience and I appreciate the great help everyone provides here. It's great stuff for everyone to know.
Antone
2015 Forest River FR3 30DS - No Ragrets
Toad - 2011 Jeep Wrangler
Antone is offline   Reply With Quote
Old 01-31-2016, 01:27 PM   #13
It helps to flush the crud out of water heater at least once a year.
Harkerr is offline   Reply With Quote
Old 02-01-2016, 09:07 AM   #14
BillyBass's Avatar
Why don't you put a water filter on your hose when filling it or if using city water hook it to it
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 02-01-2016, 09:37 AM   #15
Antone's Avatar
I do use a filter, but it may be time for a new one plus a new anode rod. Most trips have been local to So Cal. Our water is not great.
Antone
Old 02-01-2016, 09:45 AM   #16
How did HOT Water enter your Toilet? If so you have a Supply issue ! Youroo!!
Old 02-01-2016, 09:50 AM   #17
Youroo - Your question has been posed before and has been the subject of various forum discussions. Some people swear the toilet is served by hot water, others, not so sure. As far as I can determine, the issue has never been resolved. It does seem that sediment from the hot water heater tends to frequently find its way to the toilet before kitchen and bathroom sinks. As they say "go figure".
2013 Smart Car TOAD
Old 02-01-2016, 09:57 AM   #18
Thus my second part,You have a Supply Issue! How many Houses have HOT WATER FLUSH! If you were the second person to use it would give you the RED *****! Youroo!!
Old 02-01-2016, 10:08 AM   #19
StephanFR3's Avatar
The stuff I found was plastic from drilling holes in water tank during manufacturer.
StephanFR3 is offline   Reply With Quote
Old 02-01-2016, 01:18 PM   #20
Mine plugged up the toilet. Cleaned it all out and blew the lines with an air compressor. The anode rod corroded and clogged it up. Changed the anode rod and all good after that.
2015 FR3 30DS
MaltnHops is offline   Reply With Quote
water
