Old 08-19-2015, 07:13 PM   #11
Former Full Timer
Duckogram's Avatar
Find your owners manual here:
Owner Manuals | fleet.ford.com
Then turn to page 115 of your hymnal and find that it is 7.0 Quarts. (6.6L) of 5W-20 Motorcraft Oil. Synthetic is not specified.
I use a drill pump to get the oil in quickly and neatly.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 08-19-2015, 07:22 PM   #12
leisurelarry's Avatar
That sounds like a great idea!
leisurelarry is online now   Reply With Quote
Old 08-19-2015, 07:26 PM   #13
That is a synthetic "blend". I buy the 5 gallon jugs also.Click image for larger version
Name:	ImageUploadedByForest River Forums1440030397.213692.jpg
Old 08-20-2015, 07:35 AM   #14
StephanFR3's Avatar
What is the actual torque spec for the drain plug? Not rule of thumb. I previously found one, but no way is it correct it was too high.
StephanFR3 is offline   Reply With Quote
Old 08-20-2015, 11:04 AM   #15
Former Full Timer
Duckogram's Avatar
Here is the chart I use:
http://hollonoil.com/OCH/Engine%20Oi..._1995-2014.pdf
Note: It only goes up to 2011 for the V-10 and it does not specify 20 or 30 valve.
Translation: 10ft lbs or 14 Newton Meters or 110 lb/in
or seat the plug then 1/4 turn.
Overhead question: Does it not depend on what type, if any, gasket you are using?
Old 08-20-2015, 11:40 AM   #16
StephanFR3's Avatar
Wouldn't 10 ft/lb be 120 in/lb?
Old 08-20-2015, 05:41 PM   #17
Former Full Timer
Duckogram's Avatar
I used rounded numbers to represent the average in a range of torque values. It was not meant to be an exact or a lesson in conversion. or is that just your way of saying thanks?
Old 08-20-2015, 06:12 PM   #18
StephanFR3's Avatar
Thanks for the chart, but I was teasing you on the simple math mistake.
