Old 06-13-2015, 06:05 PM   #1
oil capacity
Ok I give upwhat is the oil capacity on the 2014 FR3 30DS damn if I could find it in the manual Thanks for any help ! Changed oil used Mobil 1 But it doesn't look to be all the way up on the dipstick .Used motorcraft filter ! Getting ready to be a full time RV'er on the 30th,can't wait (I think ) SEMPER FI ! Hope to see you down the road
bigdocron is offline   Reply With Quote
Old 06-13-2015, 06:14 PM   #2
Tinkerer and Putterer
I assume it is a Ford V10 and if so it is 6 quarts of 5W20 including the filter. FYI Ford uses synthetic if you want to match oil for oil.
HappyGuy is offline   Reply With Quote
Old 06-13-2015, 06:22 PM   #3
Some V10's take six but most take seven. Best to find out which one it is for you.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-13-2015, 07:20 PM   #4
VinceU's Avatar
Ford class A chassis use the newer V10 engine need 6.5-7 qts. Engine is 3 valves per cyl and have small oil coolers above the oil filter. Class C motor home have the orig slightly smaller V-10 and use 6 qts. I owned both so it's known to me. BTW it's like 290 HP vs 360 HP between em.
Old 06-13-2015, 08:29 PM   #5
wayne and sherry's Avatar
I just changed the oil in my 2015 FR3 30DS and it took 7 qts to fill in the dip stick markings with a Bosh filter..
JeNNY (2015 FR3 / 30DS)
2000 Jeep TJ Moab Rock Crawler
2013 Jeep JK
USS Seattle (AOE-3) 84-88 Wayne
US Army 06-15 Sherry
wayne and sherry is offline   Reply With Quote
Old 06-16-2015, 04:47 PM   #6
Technorick's Avatar
Changing oil. Did you use a funnel with a flexible tube and reservoir?
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 06-16-2015, 07:25 PM   #7
oil capacity
Thanks to everyone for their there help I this forum is awesome !! SEMPER FI
Old 06-17-2015, 04:18 AM   #8
Technorick, I used a one qt. oil bottle, a steady hand and poured slowly eh. My oil came in a 5qt jug so I would just fill my 1qt bottle and put the oil in one qt at a time.
2013 Jeep JK
Old 08-19-2015, 05:09 PM   #9
PhotoMaster's Avatar
I was about to change the oil on my 2014 30DS and my big concern was putting the oil in because of how high the fill port is. Using one quart bottles is what I was figuring on doing.
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
Old 08-19-2015, 06:52 PM   #10
leisurelarry's Avatar
Yes with a flexible long spout funnel, that's what I use, slow and tedious but a money saver.
leisurelarry is offline   Reply With Quote
