Old 09-22-2015, 11:30 AM   #1
Oil change ramps
I was looking for a set of ramps to make it easier to get under my 30 ds for doing oil changes and installing my suspension mods. The strongest set I found were a plastic set rated only for 16k gvw.
I ended up building a set from 2x12s that clear everything underneath including the generator exhaust and work well. However, their is not clearence for a tire stop so someone has to tell me when to stop.
The 6 layers of 2x12 are 66", 56", 46", 36" 26" , and 18". To ease the transition I put a 1x4 11.5" long at the nose of each 2x12 "step" each layer is screwed together with several 3" deck screws.
Name:	ImageUploadedByForest River Forums1442939267.070687.jpg
ID:	89556Click image for larger version
Name:	ImageUploadedByForest River Forums1442939284.737241.jpg
ID:	89557Click image for larger version
Name:	ImageUploadedByForest River Forums1442939298.873587.jpg
patanke is offline   Reply With Quote
Old 09-22-2015, 12:35 PM   #2
StephanFR3's Avatar
Harbor Freight has 6 ton jack stands and 20 ton bottle jacks when on sale price not that bad.
StephanFR3 is offline   Reply With Quote
Old 09-22-2015, 03:17 PM   #3
HAPPY WHEN RV'ING
drivmsafe's Avatar
Oil change ramps
Well done patanke!
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 09-22-2015, 07:51 PM   #4
With that lathe you have, I expected a solid piece milled out of Aluminum. But thanks for not showing off and giving us a humble example for us to follow. Lol. Great shop btw! Wish our FR3 had a home as such. Too bad our 30x40 barn is a little too short. Guess I need another out building.
KansasFR3 is offline   Reply With Quote
Old 09-22-2015, 08:06 PM   #5
gashog's Avatar
Very nice, but why couldn't you put a stop on the front one?
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 09-22-2015, 08:56 PM   #6
2007 WildCat 32QBBS
05CrewDually's Avatar
Originally Posted by KansasFR3 View Post
With that lathe you have, I expected a solid piece milled out of Aluminum. ......
Looks like a 3 axis CNC mill.
Ramps like that is the way to go. The only thing better would be a 4pc. wheel lift system, but uneccessary for just oil changes and would cost alot more money.
05CrewDually is offline   Reply With Quote
Old 09-23-2015, 10:00 AM   #7
Doh, I built all 4 the same, and missed that. There is more than enough clearence in front. Thank you gashog
Thanks for the workshop compliments, my farm workshop is not a normal farm shop. I have a cnc mill, cnc lathe, and a 6x16 welding table .... When I get the fr3 out I'll post a shop picture.
Old 09-26-2015, 12:42 PM   #8
PhotoMaster's Avatar
Getting ready to do an oil change myself. Was going to use the levelers to raise the front wheels just long enough to put boards under the wheels and pull the levelers back. I figured with the back wheels blocked and the front up on blocks I'd be good to go. Any suggestions on this idea?
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
Old 09-26-2015, 12:51 PM   #9
Pretty much what I do. I use the jacks all the time for maintenance. Just changed our oil today. Ready for the Amana trip this weekend.
Old 09-26-2015, 12:59 PM   #10
Just getting all my information together. FL-820S filter and 7 quarts of oil. I need to double check the viscosity since I've heard 5W-20, 5W-30 and 10W-30. I'm going to double check the filler cap because I know it's marked on there. I'm also going to pick up the funnel with the reservoir because the location of the oil fill is difficult to work with. Picking everything up today.
2014 FR3 30DS
