Old 03-06-2018, 02:17 PM   #1
Outslide receving slide frame pulling away from RV
I have a 30 DS 16 that the outside receiving living room slide frame is pulling away from the rv (back by the bathroom), it's worse on the bottom and gradually gets better at the top. From the pictures you will see that this frame (the frame that receives the slide when the slide gets sucked into the rv) has been pulled out by force somehow to the point where the screws have been stripped out. Not sure how this happened. When the slide is sucked all the way into the rv side, there is still a gap (you can see the slide pulley in the picture) because the aluminum slide frame is bent away and not even the force of the slide will suck the bent frame back against the side of the rv.
Anybody else seen this? It needs to go in the shop so that the screws can get set back into the frame.
FYI, the slide has been a bit loose from the beginning where we needed to add the aluminum strips on each underside of the slide in order to tighten the gap up in order to keep it from shifting around (squeaking while driving). I can't see that being a problem here however.
Name:	Slide Frame 1.jpg
ID:	164437   Click image for larger version
Name:	Slide Frame 2.jpg
ID:	164438   Click image for larger version
Name:	Slide Frame 3.jpg
Combatcoal is offline   Reply With Quote
Old 03-19-2018, 06:19 AM   #2
Had the same issue. The screws had been sheared somehow. It was a fairly easy fix though. Just get the same size screw, and replace. The rubber gasket easily slides out of it's track.
followingfreddy is offline   Reply With Quote
Old 03-19-2018, 07:29 AM   #3
Thanks Freddy, any idea what force would have caused this? Shear force would have meant the looseness of the slide moving forward and backward ( front to back)
Old 03-21-2018, 06:46 AM   #4
No idea how it occurred. May have been present at delivery, and not noticed 'til a month or two later.
frame, slide
