Old 07-09-2018, 07:55 PM   #1
Overhead bunk assembly
2015 FR3 30DS. Does anyone know if the two brackets, connecting the two sections of the overhead bunk, are supposed to be loose and bent?
Thanks,
Curt
Curtpg is offline   Reply With Quote
Old 07-09-2018, 08:54 PM   #2
TLAK's Avatar
Not sure I understand, but I'll take a shot. If the brackets are the magnetic cups screwed to the ceiling then yes they have to be loose.
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 07-09-2018, 11:31 PM   #3
rk06382's Avatar
Thanks,
Curt
Pictures please!
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is offline   Reply With Quote
Old 07-16-2018, 02:56 PM   #4
Nope. They broke on ya same thing happened to ours fr sent us new ones but the screws in the bunk were totally bent. We replaced them with high grade nut bolt and washers lock washers and also used teflon washers. .. our bunk went down once! And busted. Poorly engineered system ..
colourful64 is offline   Reply With Quote
Old 07-17-2018, 01:45 PM   #5
Hogq's Avatar
The bunk brackets on my 2015 FR3 were aluminum. And were badly bent, not sliding properly, the bunk would lower slowly, then slam down at the end of the travel. I ordered replacement slide brackets (dealer charged me like 35 bucks for them). The replacement brackets are steeland have a lip bent into one edge for strength. I plan to find or turn 4 shoulder bolts so the slides can work properly. Something on my "to-do" list. I also need to find or make a ladder.... The original isn't there any more.
2015 fr3 30DS, added 2nd A/C-Heat Pump, converted to 50amp, CHF with Hellwig Links, Progressive Power Management, TPMS, Blue Ox True-Center, Koni Shocks, HID Headlamps, LED Foglamps, Pioneer Stereo, Keyless entry, Auxiliary Cooling Fans for A/C Condenser.
Hogq is offline   Reply With Quote
Old 07-17-2018, 05:06 PM   #6
What?!
DutchRv is offline   Reply With Quote
Old 07-18-2018, 07:16 AM   #7
Hogq's Avatar
Oh, I meant the bunk ladder is missing.
Old 07-18-2018, 09:19 PM   #8
TLAK's Avatar
On mine the ladder is strapped to the ceiling of the garage, or pass through storage in the rear compartment on the passenger side.
2015 FR3 30DS
bunk
