Old 11-03-2015, 05:03 PM   #1
Overhead bunk bed
2016 fr3 30ds
wzaatar is offline   Reply With Quote
Old 11-03-2015, 05:06 PM   #2
Overhead bed will not come up.
Old 11-03-2015, 06:01 PM   #3
Check the breaker for anything tripped. If all good, check the fuses.
If it's making noise, but not moving, it's probably the motor.
2015 FR3 30DS
MaltnHops is offline   Reply With Quote
Old 11-03-2015, 08:58 PM   #4
I checked all breakers and fuses in the bedroom and all good. None of the fuses were labeled for the overhead bunk. It is not making any noise when you try to raise it which leads me to believe it is a fuse. Any idea where the fuse for that overhead bed is located.
Old 11-04-2015, 12:41 AM   #5
HAPPY WHEN RV'ING
drivmsafe's Avatar
Look at my reply in you post on "ask a rep".
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 11-04-2015, 08:30 AM   #6
Thank you all for the responses. It was a 10 amp fuse by the house battery compartment in a black housing. It was the response from Eric that helped locate that fuse easily.
Old 11-04-2015, 08:31 AM   #7
The fuse for the bunk is located in the external battery compartment right next to your steps. You will find 4 possible fuses down there, start on the left hand side and look for one that is a 10AMP fuse. The fuse will be covered in either red or black rubber holder. One way to save the fuse for the bunk is to shut off the power to the bunk unless you are running it in the down or up position.
bed, bunk
