Old 07-08-2018, 11:05 AM   #1
Overhead bunk not coming down all the way
We just bought a brand new 2018 FR3 32DS a few weeks ago. We have taken it on 2 short weekend trips with no issue. Yesterday I got in turned generator on to start packing for our long trip and the over head bunk would only come down several inches and stop. The left side seems to come down and the right side not almost like it is off sync. It has power and fuses seem fine. We leave in 2 weeks and not sure our dealer will be able to get approval to fix under warranty before we leave. Anyone have any ideas how we can fix it ourselves to have for the trip? We have small kids and need this bed area. Thank you in advance.
Menke06 is offline   Reply With Quote
Old 07-08-2018, 04:54 PM   #2
rk06382's Avatar
Remove the small panel that the switch control is on. Check the wires. Couple of weeks after I got mine the awning quit & found a unplugged wire on switch. I just pushed it back on the switch.
The bunk has two solenoids that need power to unlatch the bunk before it can lowered. Do both solenoids retract?
How you find a simple fix.
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is online now   Reply With Quote
Old 07-08-2018, 05:07 PM   #3
Lacey's Spring, AL
formerFR's Avatar
you need to 'sync' the motors, since one side is obviously off: when it does not come down all the way, immediately take it back up to the top, and visa versus until it eventually gets in sync and goes all the way.
No dealer required.
and, make sure you have pulled any 'pins', if any.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 07-16-2018, 03:03 PM   #4
Are your brackets bent? Ours were broken when we got it ..b
colourful64 is offline   Reply With Quote
Old 07-17-2018, 12:56 AM   #5
Our brackets bent
Old 07-24-2018, 06:53 PM   #6
If the motors are not in synch they will burn each other out. The header plate above the bunk has to come out to access the motors.
2017fr3 is offline   Reply With Quote
bunk
