Old 03-10-2016, 08:40 AM   #1
KsWhoDat's Avatar
Photo magnets
Anyone come up with a way to attach photo magnets to the "non-magnetic" fridge? We've acquired quite a few over time and would like to put them on the fridge. We have some on the vent over the stove, but not enough room.
thanks
Jim & Cyndi
2014 FR3 30DS
2005 Dodge Dakota 4WD
KsWhoDat is offline   Reply With Quote
Old 03-10-2016, 08:49 AM   #2
SeaDog's Avatar
One idea might be to go to Home Depot and pick up a sheet of thin tin flashing, Paint it to match the fridge then attach it with several spots of contact cement and you have a magnetic surface for your pics. Just a thought
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-10-2016, 09:12 AM   #3
Pickin' & Campin'
My wife has used *THESE* for things like you mentioned.
I believe there are more heavy duty ones as well.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 03-10-2016, 09:13 AM   #4
Herk7769's Avatar
By "tin" I assume you mean sheet metal (steel). Tin is not magnetic and a magnet will not stick to it.
Since the plastic "face" of the Dometic fridge (not the stainless steel fridge) is designed to be removed so decorative wood panels can be used, the black plastic sheet can be removed and replaced with powder coated or painted sheet metal as SeaDog suggested.
The advantage of removing the plastic rather than gluing a piece of sheet metal to it will allow you to return the fridge to OEM if you ever decide to upgrade the FR3.
The Stainless Steel fridge is a problem because stainless is also "not magnetic" (except for one formulated with a large percentage of Chromium).
Here is an article on 7 possible "fixes" for fridge magnets that don't stick.
Stainless Steel And Refrigerator Magnets - 7 Solutions | eBay
HAM CALLSIGN - KC3FFW
Old 03-10-2016, 09:18 AM   #5
SeaDog's Avatar
I just had a thought a person could attach sheet metal to the inside of the plastic face removing the face and doing a quick test with fridge magnetic and sheet metal might be worth the time, keeping the same outside appearance.
Yes I did mean sheet metal
Retired Navy
Old 03-10-2016, 09:32 AM   #6
Herk7769's Avatar
I knew that JK
My only thought about sliding it behind the plastic (which might fit), the magnets could scratch the plastic. The metal would be easier to repaint if it got too scratched up.
Old 03-10-2016, 10:03 AM   #7
We use 3M command strips that have a magnetic strip attatched to them,
Kevin & Judy is offline   Reply With Quote
Old 03-10-2016, 10:05 AM   #8
Fulltime family RVer
Wouldn't Museum Putty work?
Old 03-10-2016, 10:08 AM   #9
Blue Tack works well also. Probabally the same thing as musuem putty .
Old 03-12-2016, 08:05 AM   #10
KsWhoDat's Avatar
thanks to everyone for the tips & ideas. Will check them all out.
Jim & Cyndi
2014 FR3 30DS
