Old 11-24-2016, 09:21 PM   #1
Plug in or not?
Does anyone leave their FR3 plugged into shore power over the winter? Is the an advantage or disadvantage in doing this?
Sgtmac is offline   Reply With Quote
Old 11-24-2016, 09:39 PM   #2
I don't have an FR3. I keep my RV plugged in to shore power all the time when not using such as in winter time. In the summer I set my thermostat to 80. In the winter I set to 50. I check the battery water once a month due to charging while plugged in.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 11-24-2016, 10:25 PM   #3
I don't have the FR3 also. I have an external volt gauge on my battery box
that I check every few days, when the battery gets below 10 volts I turn the 30 amp breaker on for a day or so then turn it off etc.
James & Amy
2016 246RKS Freedom Exp.
2006 Toyota Sequoia
It's a nice night for an evening
woodpile is offline   Reply With Quote
Old 11-24-2016, 10:30 PM   #4
Leave it plugged in! Check battery water monthly and fill as necesary.
donniedu is offline   Reply With Quote
Old 11-25-2016, 01:14 PM   #5
Kadiddle's Avatar
x2 what donniedu said. I have an FR3 and leave it plugged in all year long. FR3s have a smart charger that won't overcharge. Be sure to check the water as stated and use distilled water to top off.
In my previous motorhome with a dumb charger (i.e., full charge all the time), I put it on a timer to charge for only :30 per day.
2015 FR3 30DS
2010 Ford Escape Toad -or- 2012 Ford Focus Toad
Kadiddle is offline   Reply With Quote
Old 11-25-2016, 01:39 PM   #6
Don't have one either but I take it as a generic statement. I leave my unit shore powered all winter even though it's inside my shop. I use mine (refrigerator) to keep my beverages cold so when I'm working in the shop, I still use it... I've always done that for years...
SidecarFlip is offline   Reply With Quote
Old 11-25-2016, 01:43 PM   #7
Plugged in.
If you have a automatic rhree stage converter with a float/trickle mode, should you even have to worry about overcharge or checking water levels?
markb422 is offline   Reply With Quote
Old 11-25-2016, 02:40 PM   #8
DaveSchwartz's Avatar
I have a 3-stage WFCO that is the subject of some scorn here but I plug in all the time when at home in the driveway. I have a 12v outlet digital voltmeter (less than $3 on eBay) plugged into the socket by the bed... always reads 13.2V (float mode) and have not had to add water over two winters.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 11-25-2016, 03:29 PM   #9
waiter21's Avatar
I ;leave my Mirada plugged in during winter storage.
I have a four stage converter that makes sure the battery doesn't get over charged and boil the battery.
I make sure everything is turned off, and leave one of the roof vents open an inch so the inside can breath.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 11-25-2016, 05:50 PM   #10
When I am home during the winter, I take out the battery and store in on a piece of would in my house, winterize the RV and shut everything down. No shore power. I'll be damned if I give Ontario Hydro one more penny than I have to.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 11-26-2016, 07:27 AM   #11
We do the same BusyRetirees. Ontario Hydro already charges me a monthly fee on the hydro at camp, and the breaker is turned off.
johnpisue is offline   Reply With Quote
Old 11-26-2016, 07:54 AM   #12
ilmor's Avatar
My motorhome has a nice 3 stage charger however I still like to bring my batteries to my garage during the winter. I clean them up, keep an eye on them (distilled water levels), charge up as necessary.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 11-26-2016, 08:50 AM   #13
World Wide Wanderer
wahoonc's Avatar
Ditto
Same here... we use the RV for overflow during the holidays in particular. Both for food storage and people.
No on overcharge/undercharge unless the converter decides to crap out on you. I have had a couple WFCO go bad in the past. I check mine unit at least once a week to make sure the battery is charged up. I check water every 3 months as part of routine maintenance. We purchased our unit in Feb 2016, I haven't had to add any water yet.
I had a Coleman TT, came home from a week on the road for work, turned the LED lights on and they were very dim. Turns out the WFCO had crapped out and the battery had gotten pulled down by the phantom loads. A bit of trouble shooting confirmed the converter was toast. Recharged the battery using a stand alone charger, ordered a new Progressive Industries converter. Problem solved.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 11-30-2016, 10:56 AM   #14
Same converter/charger here and I've only had to add a few ounces of water since spring of 2014. I still check the water levels monthly but have been very (pleasantly) surprised at how little the batteries have needed.
jrwalkerpa1 is offline   Reply With Quote
