Old 07-04-2018, 10:32 AM   #1
Power Problem when Dry Camping
Last night we dry camped and could not get power to the TV , air conditioner and microwave when we parked and started the generator. I reset all the breakers several times including the bathroom plug in. Breaker, the breaker switches in the bedroom and the breaker switch at the generator. I also shut off the coach power at the steps. We also turned the fridge and hot water to gas beer trying to power up generator. Finally, the air conditioner was in the off position before we powered up the generator.
Woke up this morning and turned the breaker switch in the bedroom on and reset the bathroom plug in breaker switch and everything worked. I did not move the coach or anything else.
Can anybody tell me why this happens?
Thanks,
Bob
Dolce2017 is offline   Reply With Quote
Old 07-04-2018, 10:51 AM   #2
World Wide Wanderer
wahoonc's Avatar
What is the make and model of the unit, and generator?
Sounds like it popped the GFCI, but not sure why that would knock everything out, typically when a GFCI pops it only takes out a few items. Also what is the "breaker" in the bedroom? All my breakers are in the breaker panel at the converter.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 07-04-2018, 11:54 AM   #3
Aaron
No power to GFCI. My breaker box is in bedroom on my FR3 28 ds 2015.
Old 07-04-2018, 12:02 PM   #4
Do you really have a Transfer Switch? Youroo!!
Old 07-04-2018, 12:02 PM   #5
Do you have a transfer switch, or manually move the electrical plug when on the generator? It sounds like your transfer switch didn't switch over to generator. The problem is most likely not the GFCI as the A/C and usually the microwave are not on a GFCI circuit.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 07-04-2018, 12:34 PM   #6
jkoenig24
"We also turned the fridge and hot water to gas beer"
What is this "gas beer" you're trying to run on?????
jkoenig24 is online now   Reply With Quote
Old 07-04-2018, 03:43 PM   #7
No transfer switch. My breaker is in the bedroom.
Old 07-04-2018, 04:17 PM   #8
You manually plug into the generator? Do your have power there? Power at the converter? Power coming out of all breakers?
Old 07-04-2018, 04:37 PM   #9
World Wide Wanderer
wahoonc's Avatar
Do you have to plug your power cord into a plug on your motor home when you use the generator? The same wire that would go to the power pole.
Aaron
Sent from my XT1254 using Tapatalk
Aaron & Rhonda
Old 07-04-2018, 06:03 PM   #10
The generator is built in from the factory. It worked this afternoon when I obtained gas . During my drive I shut off all the breakers and the hfci switch in the bathroom outlet. After I started the generator and let it run for 30 seconds then I turned the breakers on then the hfci switch in the bathroom. Everything worked.
I will try again tonight when I stop tonight.
Thanks,
Bob
camping, dry camping, power
