Old 11-23-2015, 01:00 PM   #11
Antone's Avatar
Originally Posted by GSlone View Post
My alarm is going off (beeping) in my new trailer, it is sitting in a lot, no shore power, battery out, and propane tanks disconnected. So anyone know why it would be beeping?
It may be because the battery is low or out. I previously owned a FR TT and it would happen in those cases.
Antone
2015 Forest River FR3 30DS - No Ragrets
Toad - 2011 Jeep Wrangler
Antone is offline   Reply With Quote
Old 11-23-2015, 02:14 PM   #12
KMA
Originally Posted by Antone View Post
So this brings me to a question. Is it best to leave the tank on or shut it off after each trip? I've heard both, but I'm curious if anyone has experienced any negatives from either way.
Antone
After the incident, I shut it off when not in use. At the campsite I shut it off before going to bed (I use electric heater anyways).
Negatives would be...hot water is not ready immediately, couple extra trips to propane tank to open/close valve to take shower, use heater etc.
Hope my regulator diaphragm doesn't pop when someone having campfire right next to my propane tank or light up cigarette...
Wonder if there's any auto leak detecting shut off switch that you could install before the regulator..?
KMA is offline   Reply With Quote
Old 11-23-2015, 03:09 PM   #13
CDR USN Ret
An excellent treatment of propane cylinder safety. Dispels many myths.
Propane 101-The basics
DSQR is online now   Reply With Quote
Old 11-23-2015, 03:27 PM   #14
I would leave the main valve off. I returned from a camp trip and upon double checking my unit smelled gas and the alarm was going off turns out when my wife was wiping the oven she turned one of the valves slightly on
Buckeye Traveler is offline   Reply With Quote
Old 11-23-2015, 06:28 PM   #15
The FR3 air is also a heat pump, that takes care of the heat.
The hot water tank has an electric element in it that can be flicked on in the hot water tank area from the outside. That takes care of the hot water, no need to use propane if you choose not to.
Good luck.
Wjl7110 is offline   Reply With Quote
Old 11-23-2015, 07:34 PM   #16
KMA
Good luck.
Forgot that new models have heat pump and electric heater. Unfortunately mine was made mid 2013 and only propane.
Old 11-23-2015, 07:35 PM   #17
Rivnut
Rivnut's Avatar
check battery on smoke alarm, gets me every time or the CO@ monitor. Those thing go bad with no repair jut dies in a few years, have to get new one.
Rivnut is offline   Reply With Quote
Old 11-23-2015, 10:02 PM   #18
Three of the four regulator failures we had were when the coach was stationary. One of them was sitting in the Dealers lot. Our service rep walked by and heard the leak. You never know when a regulator will fail. I now firmly believe that anytime the propane system will not be needed it should be off at the tank.
Writing this I came to a realization. The Winnebago had solenoid operated tank cut off switches. One in the coach and one in the regulator bay. I switched it off in the bay twice. I never thought of the possibility that the electric switch could have set off a propane explosion. Wow that is scary. What about a manual valve you have to go to on the tank to shut off? I know the recommendations about propane are that if their is a leak get out and away from the source. Seems most regulators are in the same bay as the propane valve. So if you smell or hear a leak should you really go to the bay and shut off the tank valve or just get away and call the fire department and clear your neighbors out of the area?
cev1001 is offline   Reply With Quote
Old 11-24-2015, 11:20 AM   #19
Antone's Avatar
Great info everyone. I will be shutting mine off when not in use now.
Antone
Old 11-24-2015, 04:03 PM   #20
Mine went off the other night. It turned out the circuit breaker opened to the converter and the battery was way down.
NorSnrub is offline   Reply With Quote
propane
