Old 09-05-2015, 08:13 PM   #11
Former Full Timer
Duckogram's Avatar
Originally Posted by Lexi2007 View Post
Thanks for the really quick reply Duck,,,
Newbie here, would you mind expounding on the reasons why we would need glue and loctite, wire, wall paper knives, ratchet straps please?
Regards.
The glue is made by loctite. Safety wire in case clamps break. Wall paper knife to cut whatever or shave whatever. Ratchet straps for pulling and holding like if a slide breaks...
Example of why:
So there I was headed around a right turn and the drawer under the oven with pots and pans flies open tearing the face of the cabinet out along with the cheapness particle board that the rails mount to. So I remount the block to the floor of the slide and reset the rail mounts then a bead of gorilla glue to firm things up. The front gets a golf tee in the stripped holes with gorilla glue and the face board gets glued, screwed and C clamped to hold it in place until the glue dries. Then I added 2 additional spring closers to the drawer, redrill the holes and replace the anemic 1/2" screws with 1". The drawer is solid and has never popped open again after 15,000 miles of driving. Thats why you carry "stuff" when you are on the road for Months at a time.
BTW, you might need some red loctite for the bolts the hold the rear anti-sway bar to the axle... just sayin.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 09-05-2015, 08:32 PM   #12
f5moab's Avatar
Originally Posted by StephanFR3 View Post
Box of rubber gloves.
Afraid to ask what you do on your trips
f5moab is offline   Reply With Quote
Old 09-05-2015, 08:57 PM   #13
Lexi2007's Avatar
Example of why:
Thank you for helping me visualize why you included such things in your original post. BTW, are you available for adoption?
Ken & Val [Lexi's mom] Moczygemba & Tori the dog
Adkins, TX
2017 Coachmen Concord 300 DS [Lexi III]
Lexi2007 is offline   Reply With Quote
Old 09-05-2015, 09:44 PM   #14
StephanFR3's Avatar
If one of my slides were to break I have precut blocks of wood that I would set on top of interior slides to hold them in after I manually pushed them back in.
StephanFR3 is offline   Reply With Quote
Old 09-05-2015, 09:47 PM   #15
StephanFR3's Avatar
BTW the wood could double as shoring for jack pads if on a big hill.
Old 09-06-2015, 09:08 PM   #16
Lexi2007's Avatar
'Nother Question
1.Does anyone else have issues with the engine noise in the driver/passenger area? We took the cowling off and saw some insulation that included a fireproof layer. Is it safe or adviseable to perhaps spray the inside of the cowling with some additional noise dampening product? Also, what about laying pieces of carpet beneath our feet?
2. Does anyone have any suggestions for strengthening the latch that holds the outside door to the screen door? It just seems so flimsy plus I've broken a truck load of nails grabbing the hand hold to pull the outside door shut.
3. Our son just purchased a travel trailer and he swears they told him to not run the A/C through the vents, just let it come through to large vent attached to the actual unit. Thoughts?
As always, ya'll are just awesome and full of really good ideas and suggestions. There's no way I can ever fully express our appreciation. Except if we happen to run into each other at a campground some day, and then... and
Adkins, TX
Old 09-06-2015, 09:22 PM   #17
bubbles's Avatar
For a cup holder google drink holders for boats. Our unit came with one that folds up and is secured to the plastic siding. Had one just like it in my boat.
Old 09-06-2015, 09:53 PM   #18
asquared's Avatar
The rubber gloves are for sewer dump.
To the OP... We carry an air compressor, a basic tool kit something along these lines. We also have a rubber mallet, cordless drill, plumbers tape, electric tape, duct tape, buggy cords, extra fuses of all needed sizes, a small axe, trailer aide to Jack up.our fiver (you probably need a heavy duty bottle Jack for the fr3) and caulk. We have been meaning to buy some eternabond also. Some good things to have are extra fresh water hose, power extension cord, a surge protector (hard wired or portable), and extra sewer hose.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-06-2015, 09:58 PM   #19
Former Full Timer
Duckogram's Avatar
1. By cowling I assume that is the engine cover. Open up the front grill and look up. You will see the bottom of the dash and NO insulation. So far, hush mat brand is the leading solution. I added a couple of rubber bottom bath rugs to the front floor which helps with noise and heat as well. I would not put anything flamable around your V-10.
2. There are better latches and door hardware available. Check out the one on the Winne...
3. Tell your baby boy to stop swearing. You can run your ac through the ducts or through the chill grill. If you want the bath and bdrm cool, the ducts will be your best bet.
Old 09-17-2015, 08:03 PM   #20
For the cup holder: go to Amazon, they have several that can be attached to the wall under the window and do not interfere with the co-pilot seat turning.
J1BCU is offline   Reply With Quote
