Old 01-17-2016, 10:49 AM   #1
Radio Antenna
Can someone tell me how to lower the radio antenna so I can put the cover on the motor home for winter storage. I don't want to put a hole in the cover.
progolfer is offline   Reply With Quote
Old 01-17-2016, 11:19 AM   #2
Lvn2tvl's Avatar
Radio Antenna
If it is on top I remove the screw and pad the remaining part with a foam block or old pillow on my 5er. Not sure if this is where yours is located.
2018 Cedar Creek Silverback 29IK
16 Silverado 3500 HD 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
Lvn2tvl is offline   Reply With Quote
Old 01-17-2016, 05:54 PM   #3
There is a small phillips head screw attached at bottom. Just remove it an dont lose the screw.
jogalot is offline   Reply With Quote
Old 01-20-2016, 12:54 AM   #4
Motoring
grotto69's Avatar
loosen the screw. antenna folds down. tighten screw until next season then reverse the process in Spring
grotto69 is offline   Reply With Quote
Old 01-20-2016, 07:54 PM   #5
from Cali
RV Pilot's Avatar
Mine also had a screw on it that allowed it to be loosened and laid down parallel with the roof.
2015 FR3 30DS
Central Coast of California
______________________
2015 FR3 30DS
2014 Jeep Rubicon X
RV Pilot is offline   Reply With Quote
Old 02-01-2016, 04:37 PM   #6
Radio Antenna
Just leave the antenna down all the time. Mine hit a tree branch somewhere along the line and pulled the screws out and pulled the cable out of the connector. My buddy's FR3 apparently had the same thing happen because there was an obvious patch in the caulk. Radio reception is not affected by laying it down.
dutiful Don is offline   Reply With Quote
antenna, radio
