Old 03-27-2018, 12:42 PM   #1
TLAK's Avatar
Radio/DVD dead
2015 FR3 30DS. Pioneer AVH-X3600BHS Head Unit.
Driving through Arizona listening via blue-tooth, the radio made a snapping sound and went dead. Screen is blank, so no cameras. At the next gas stop I reached behind it to wiggle around for loose connections and it came alive showing a debug screen then it died again. Now it's dead as a door nail. I pulled the dash cover and didn't see any fuses on the back of the unit or in the line feeds. I looked at the fuses in passenger compartment driver's side box and none appear blown. I pushed the pen tip reset on the unit, nothing. All the other rocker switches (shade, led lights) work. The light on the radio rocker works when the vehicle lights are turned on.
Has anyone dealt with this? Didn't see anything in search. Is there is a dumb solution I'm missing or should I put a new head unit in the budget. I need it for the backup camera.
2009 FreeLander - Retired
2015 FR3 30DS - Retired
2023 Sunseeker 2440DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 03-30-2018, 02:17 PM   #2
TLAK's Avatar
I finally found in the manual that there is a fuse on the Pioneer underneath the wiring harness. I pulled the harness off, pulled and tested the fuse, but it was good. Put everything back together and the @#$% thing worked! Something must have worked loose over the course of three seasons, 22,000 miles.
The funny part is I missed the fuse while poring over the manual several times. I accidentally opened it to the Spanish part and saw Fusible (10A) on the diagram. And, I don't speak Spanish, the writing is so small I missed it in English.
Old 03-31-2018, 11:03 AM   #3
vacationlovers's Avatar
Post
Our AVH-X2700BHS gradually became more & more intermittent, until it finally died after about one year. That model is obsolete and no longer available, but I found that the AVH-X391BHS is an exact replacement, with no re-wiring required.
2016 FR3 30DS
Thousand Oaks, CA
RV Trip Photos
vacationlovers is offline   Reply With Quote
Old 05-30-2018, 08:36 PM   #4
TLAK's Avatar
Just to update, the issue was the Pioneer wiring harness. When I opened the dash again, the yellow lead wire fell right out. On the internet I read that this harness is detested in the industry.
Ordered a replacement from Amazon and soldered the wires, leaving some extra play in them. Everything has been working perfectly through two trips.
Old 05-30-2018, 09:42 PM   #5
rk06382's Avatar
What is the Amazon link?
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 05-30-2018, 09:49 PM   #6
TLAK's Avatar
Here you go:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 05-30-2018, 10:30 PM   #7
rk06382's Avatar
Robert
Old 05-30-2018, 11:26 PM   #8
My refrigerator light will not turn on. Replaced bulb with one purchased at camper supply store. What next? It does have good contact on pointed ends.
Linda Hartin is offline   Reply With Quote
Old 05-31-2018, 06:57 AM   #9
Fridge otherwise working? Fridge is on? 12V disconnect switch? Did you test with multimeter for juice?
I bought a 10 pack led replacement bulbs, happy to send you one, that 10 pack will outlive me
DutchRv is offline   Reply With Quote
Old 05-31-2018, 07:10 AM   #10
Will find test meter to check. Refrigerator is working. May want to switch to LED once find fault. I see lots of reports with opposite problem.... won't turn off.
Old 05-31-2018, 07:44 AM   #11
If it doesn't turn off its likely the switch. Could also be the switch in your case
dvd, radio
