04-17-2017, 05:52 PM
Range hood fan not working
Can someone help me trouble shoot I don't even know where to start
04-17-2017, 06:52 PM
Left Coast
Does the light work?
04-17-2017, 07:07 PM
I would start with checking the 12V fuses and ensure all are good.
Retired Navy
2016 Flagstaff 26 FKWS
04-17-2017, 07:16 PM
Left Coast
That's why I asked about light.....
04-17-2017, 07:18 PM
Ya thats a good easy check as long as the bulb is good. I like to tackle the hard things first lol
Retired Navy
04-17-2017, 07:19 PM
The light works
Left Coast
I don't bend so good!....lol
04-17-2017, 07:22 PM
Left Coast
Can you get to the backside of fan switch?.....Need to test for power to switch...
04-18-2017, 10:56 AM
Yes I can get there and what do I do to test for power can I do it through the wires?
04-18-2017, 11:03 AM
Left Coast
You need a 12 volt test light, available at any auto parts store...Cheap one ok.....And ground the wire with clip on it, and use probe to test for power where wire meets switch, or you can Pierce wire if switch wire connections aren't easy to get to
04-18-2017, 11:06 AM
Left Coast
If light on test light comes on, then the problem will be the fan motor.....Motor gett'n power, but fan doesn't work
04-18-2017, 11:16 AM
Left Coast
Might have to try different spots to find a ground with the alligator clip......If nothing else, could slice a little bit of coating off one wire for the clip to connect to, and use the probe (sharp end), to push through coating on other wire to make contact with the actual wire.....Doesn't matter which color you probe or connect clip to.......We're checking for power to switch...
04-29-2017, 11:26 PM
LoL even if the fan comes on it still don't work. All it dose is make noise. Another FR joke.
